22873 Discussions
uhd graphics 620, second monitor doesn't work, but TV yes--> all docs attached
Gonzo2
When I plug a second monitor, it doesn't work, when I plug a TV it works (verified with 4 different monitors and cables and 3 TVs)
Intel(R) Core(TM) i7-8565U CPU
Intel UHD graphics 620
GeForce MX150
Already...:
Verified several times cables
updated windows
Updated drivers
Uninstalled drivers
repaired Whindows image
changed settings
modified energy saving configuration
attached everything please respond!!!
Senkuchan
Valued Contributor II
What is the make and model of the monitor causing this issue? For additional troubleshooting, you can check this link: https://www.intel.com/content/www/us/en/support/articles/000026580/graphics.html#:~:text=Try%20different%20monitors%20and%20display,the%20motherboard%2Flaptop%20output%20options.
Gonzo2
My standard second monitor is a Lenovo D24-20.
in any case, it happens with all the other monitors of different brands that I have tried (3 more).
As said in the description when I connect the HDMI to a TV (tried in 3 different TVs) it worked, in two of them without any issue, in another one it doesn't work but it asks "device not identified" you navigate to confirm that it's a PC and then works without any problem.
The model of this last TV is Samsung UE43TU7125KXXC.
I followed the instructions you sent and no improvement.
any other solutions?
Gonzalo
ACarmona_Intel
Hello Gonzo2,
Please try the following troubleshooting steps outlined in this article, as upon checking your graphics card specification, you can use HDMI on your system, and it can even support three displays.
If the issue still persists after following the troubleshooting steps provided, please contact your motherboard manufacturer or Dell technical support since we have general information about Intel® graphics features however Manufacturers can incorporate customizations that may not support all general graphics features.
And by the way, please make sure that it is Intel graphics that is being utilized by your laptop, as upon checking, you have two graphics cards in your system.
Thank you, and have a great day ahead!
Carmona A.
