22649 Diskussionen
uhd730核显
Alaix
Einsteiger
7.505Aufrufe
十一代处理器核显驱动玩cf穿越火线闪退怎么解决
3 Antworten
AndrewG_Intel
Mitarbeiter
7.481Aufrufe
Hello @Alaix
请注意,我仅能以英语提供支持。我使用了一个网络翻译工具来翻译此响应,因此,可能有一些不准确的翻译。
In order to assist you better, could you please provide more details regarding this request?
1- Please elaborate more regarding the inquiry/issue that you have? Is this regarding an issue with an app, game, performance, graphics or settings configuration?
2- If this is regarding a graphics problem, did the system work fine before? What is the exact problem? When did it start to happen? Was there any Windows*, Driver, Software update or hardware change when the problem started?
3- Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
  • Download the Intel® SSU and save the application on your computer
  • Open the application, check the "Everything" checkbox, and click "Scan" to see the system and device information. The Intel® SSU defaults to the "Summary View" on the output screen following the scan. Click the menu where it says "Summary" to change to "Detailed View".
  • To save your scan, click Next and click Save.
  • Once you have saved the file (.txt file), please attach it to your reply.
To upload and attach a file, use the "Drag and drop here or browse files to attach" option below the response textbox.
Andrew G.
Alaix
Einsteiger
7.473Aufrufe
我不知道是是咋回事,我自从买了这台电脑并安装上了十一代核显驱动之后就开始了,玩游戏的时候一开始是玩着卡住等一会才反应过来,然后就是卡住闪退,再然后就是卡住等反应过来就是游戏地图,贴图人物只有轮廓和白色,这是只有没安装显卡驱动才有的问题,
非常感谢您的回复,请尽快解决这个问题。
AndrewG_Intel
Mitarbeiter
7.449Aufrufe
Hello Alaix
Thank you for your response and report.
However, we understand you have opened an internal Web Ticket with us and we will continue to help you through that channel now. We will therefore close this community case. Thank you.
Andrew G.
Antworten
