hi , i got Intel-Xeon-Processor-E3-1285L-v3-8M-Cache-3_10-GHz with Intel® HD Graphics P4700, from some reason i am unable to install Ubuntu unless i am disabling the GPU via BIOS. please advise
Hello, Regev104:
Thank you for contacting the Intel Communities.
There are some things that you can check/perform on this scenario to troubleshoot it:
-Check if the Integrated Graphics is the main or primary video adapter to be used at BIOS level
-Please check if the kernel used supports Haswell's microcode.
-If it that is incorrect (not supported), here you can find some instructions related to this: https://wiki.archlinux.org/index.php/microcode https://wiki.archlinux.org/index.php/microcode
-Microcode to be used: https://downloadcenter.intel.com/download/24661/Linux-Processor-Microcode-Data-File?product=75466 https://downloadcenter.intel.com/download/24661/Linux-Processor-Microcode-Data-File?product=75466
I look forward to hearing from you and the outcome on this.
Esteban C
Thought I would just check in and find out if you were able to get this resolved with the information provided.
I look forward to hearing from you.
Esteban C
