Hello Folks:
I recently upgraded my desktop CPU from a Pentium G3258 to an i5 4690k. I cleaned my 212 EVO cooler, thinly applied new Antec 7 thermal compound and reinstalled everything. As soon as I rebooted with the new CPU, all worked except that my monitor had "No Signal" when it was connected to the graphics card's HDMI slot. The monitor image was only available via the on-board Intel Graphics 4600, connected through the motherboard's HDMI slot.
My existing Nvisia GTX 960 Gaming G1, had disappeared from my system - Windows 10 couldn't find it and it was not listed in the device manager. I pulled the graphics card and tested it on another system - working fine on all output connections. Getting help from other forums, I performed a clean reinstall of Windows 10, updated my ASRock Z97M Anniversary motherboard's BIOS, made sure that the on-board graphics were unchecked in the board's BIOS, uninstalled the 960 card and then uninstalled the Intel graphics drivers and Nvidia card drivers using UDD in Safe Mode, and finally reinstalled the graphics card and downloaded new Nvidia drivers for my card. As soon as the new drivers tried to install, the installer program stopped, saying I had no Nvidia graphics card installed. Bummer.....
So I pulled the 960 card again, cleaned it and the PCIE slots, reinstalled and made sure everything was tight, and removed and reinstalled the RAM, but still no card appeared on the system and another try at reinstalling Nvidia drivers failed. I ran the POST beep codes and got 1 short beep - "DRAM refresh failure". I ran memtest86, and passed, but still no 960 card recognized on my system. My PSU is a Corasir CX500 unit, which should be robust enough for my new setup, and worked fine with the Pentium overclocked to 4.4 Ghz.
Next step is to pull the motherboard and test all connections, but I really hate to go through all the disassembling of the system that entails. Any other ideas of how I can troubleshoot this problem?
Thanks in advance for any help.
Brian
Quick Postscript:
I also cleared my CMOS by shorting the jumpers and removing the battery for five minutes - didn't help.
Brian
Hello,bslocum:
Thank you for providing all the troubleshooting done so far.
Have you tried to go back to the previous CPU? and test the GPU with the old configuration.
Are you able to swap the new CPU to another motherboard? and test it with the same GPU?
Esteban C
Esteban:
Thank you for your reply.
I did re-install the original Pentium and checked the system, and it worked, but I don't remember if I actually checked to see if the graphics card was recognized or if I was seeing the on-board Intel graphics. Wish I had taken notes.....
I really don't want to have to reinstall the Pentium again, as the cooler is a bear to get seated correctly in my tight case.
I don't have another computer to use in checking the new CPU or the GPU. I could take them to a shop for checking, but would prefer to aviod that expense if possible.
Brian
Hello, bslocum:
Thank you for your answer on this.
Sure I understand, in this case, if you are still experiencing the same behavior from your system, my recommendation is to contact our support center for a possible replacement.
Support center contact information: http://www.intel.com/content/www/us/en/support/contact-support.html# @12 http://www.intel.com/content/www/us/en/support/contact-support.html# @12
If any additional questions or inquiries are present, feel free to contact us back.
Esteban C
