23787 Discussions
video glitch
unknownilian
  • I have a graphics problem and i don't how i can resolve it.
Can anyone help me ?
The problemThe problem
Here's my hardware :
HP Laptop 15-ra0xx
BIOS
Version
InsydeH2O Version 05.05.21F.61
Date
8/29/2019
MOTHERBOARD
Manufacturer
HP
Model
832C
Version
25.56
OPERATING SYSTEM
Edition
Microsoft Windows 10 Professionnel (64 bits)
Version (Build)
22H2 (10.0.19045)
Devices and Drivers
PROCESSOR
Intel® Celeron® CPU N3060 @ 1.60GHz
  • Device Details
  • ManufacturerGenuineIntel
  • DescriptionIntel64 Family 6 Model 76 Stepping 4
  • Architecturex64
  • # of Cores2
  • # of Threads2
  • Processor Base Frequency1601 MHz
  • Current Voltage5.4
  • Level 2 Cache1024 Kb
  • Level 3 Cache0 Kb
  • Processor Id0x406C4
  • Revision19460
  • AvailabilityRunning at full power
GRAPHICS
Intel® HD Graphics
  • Driver Details
  • ProviderIntel Corporation
  • Version20.19.15.5070
  • Date12/27/2018
  • Device Details
  • Adapter CompatibilityIntel Corporation
  • Video ProcessorIntel® HD Graphics
  • Resolution1366 x 768
  • Bits Per Pixel32
  • Number of Colors4294967296
  • Refresh Rate - Current60 Hz
  • Refresh Rate - Maximum60 Hz
  • Refresh Rate - Minimum40 Hz
  • Adapter DAC TypeInternal
  • StatusThis device is working properly.
  • LocationPCI bus 0, device 2, function 0
  • Device IdPCI\VEN_8086&DEV_22B1&SUBSYS_832C103C&REV_35\3&11583659&0&10
Jose_Intel
Hello @unknownilian
Thank you for posting on the Intel️® communities.
Our support is only provided in English. We may not be able to translate screenshots attached to the thread.
We understand you are experiencing issues with your laptop, we will be more than happy to assist you.
Please answer the following:
·      Was it working before?
·      Have you made any software change?
In case you are able to use your laptop, in order to have more information about your system, please download, install and run Intel® System Support Utility for Windows. Make sure you check “Everything” before you scan, then save the report and attach it to your response.
If you are unable to use, please let us know.
Jose B.
Jose_Intel
Hello unknownilian
We hope you are doing fine.
Were you able to check the previous questions?
Jose B.
Jose_Intel
Hello unknownilian
We hope you are having a nice day.
We have not heard back from you. So, we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jose B.
