23780 Discussions
video output problem on NUC unit
DCamp7
My NUC unit intermittently fails to send a video signal, machine still running, signal will return sometimes otherwise power down run recovery on window and away again, it also get a bit on the hot side, any help please.
Don
Hi Donald.Campbell,
I would be glad to help you with your issue. Before given to you any troubleshooting I need to know the Intel® NUC Kit model, video port and video cables, any video adapters that you are using. Also, let me know the current BIOS version of the kit and current operating system.
Mike C
Hi Donald.Campbell,
I am following your case. Let me know if I can help you with anything else.
Mike C
