23538 Discussions
video settings does not work for internet browser video
bendm
hi,
i noticed that all the settings i make in the video section don't work. i tested it with different browser video players (html5 video) as well as with kodi. for testing purposes you can e.g. set color correction to "driver" and then turn on brightness or contrast to 100% while a youtube video is running. tested with different hardware of the newest generation (i5 and gemini lake) . this is a basic problem and has nothing to do with a special driver or a special hardware. also the problem described is the cause for this:
https://forums.intel.com/s/question/0D50P0000490Z1ZSAU/problem-with-color-range-uhd630
Diego_S_Intel
Hello bendm, Thank you for contacting our Intel® communities. I understand that you are having issues with your video settings. Can you specify which settings are you having issues with? Are you using the Intel® control panel? Also can you please provide us with a longer/more detailed description of the issue and how to reproduce it? In order for me to assist you better, please provide me with the .txt file that the System Support Utility will generate. To attach a file, you must click the “Attach” option on the bottom right-hand corner of the response box. Here is the download link: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- I hope to hear from you soon. Diego S. Intel (R) Customer Support Technician Under Contract to Intel (R) Corporation
Diego_S_Intel
Hello bendm, We just wanted to double check if you still need further assistance. Please don’t hesitate on contacting us back. I hope to hear from you soon. Diego S. Intel (R) Customer Support Technician Under Contract to Intel (R) Corporation
Diego_S_Intel
Hello bendm, We just wanted to check if you still need help. I hope to hear from you soon. Diego S. Intel (R) Customer Support Technician Under Contract to Intel (R) Corporation
Diego_S_Intel
Hello bendm, We just wanted to check if you still need help. We are closing your case as we have anything back from you. Please do not hesitate on contacting us if further assistance is needed. I hope to hear from you soon. Diego S. Intel (R) Customer Support Technician Under Contract to Intel (R) Corporation
jeanbear
It sounds like you're facing a frustrating issue with video settings not applying to HTML5 video in browsers, even with the latest hardware. This issue is indeed commonly reported across different systems and isn’t specific to any single hardware or driver. One workaround you might consider is using dedicated video apps that offer more control over video playback settings than browsers currently do. For instance, apps like Snaptube allow you to adjust video quality, brightness, and even download content to play offline with custom settings. Since browser limitations can interfere with settings, a dedicated app might be a more reliable solution for enjoying video content with the exact playback adjustments you want.
jeanbear
It seems as though you're confronting a baffling issue with video settings not making a difference to HTML5 video in programs, even with the most recent equipment. This issue is to be sure normally revealed across various frameworks and isn't well defined for any single equipment or driver. One workaround you should think about is utilizing devoted video applications that offer more command over video playback settings than programs presently do. For example, applications like Snaptube permit you to change video quality, brilliance, and even download content to play disconnected with custom settings. Since program impediments can slow down settings, a committed application may be a more dependable answer for getting a charge out of video satisfied with the specific playback changes you need.
