Please provide working driver that we could be able to passthrough igpu - UHD Graphics P750 to Windows 10. It doesnt work as get error 43 in windows or blue screen when restarting VM.
Tested on supermicro x12sth-f with xenon E-2374G runing ESXi 7.0U3c (19193900), PCI device 0000:00:02.0 Intel Corporation RocketLake-S [UHD Graphics] added to Windows 10 21H2 build and is visible in device manager but it doesnt work........
Tested drivers:
30.0.101.1122
30.0.101.1002
- « Previous
- 1
- 2
- Next »
Hello Vaikis,
The issue might be address on future driver updates, we can temporarily close the case and keep it monitoring and let you know once there is a driver update so you can test it.
Sergio S.
Hello Vaikis,
We are following this thread and would like to know if we can temporarily close the case and let you know once there is a driver update so you can test it.
Sergio S.
Hello Vaikis,
Sergio S.
Hello Vaikis,
The driver that is working that is working (30.0.101.1002) is not an Intel version, it may be provided by Windows or the OEM, we do recommend continue using that version and check for more details and updates.
You can also find the the latest from Intel(R) Intel® Graphics Driver 30.0.101.1960 updates here:
https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html
Sergio S.
Driver 30.0.101.1960 doesn't work....... So iGPU on E-2374G is still no possible to use by passthrough for Windows and I know that on Debian 11 guys managed to passthrough.... Provide normal driver for sriov support as with 11th gen you dont use GVT-G anymore.
moi j ai le même problème avec mon 11700K & UHD 750
j ai tous essayer
1 laisser w10 install le pilote de base mai au reboot windows ne veut plus demarrer.
2 install une veille version de pilote et j ai l erreur 43 quand je supprime le pilote et je met ajour le device manager il me mai que la carte marche mai en fette non.
3 install une dernière version et la toujours erreur 43
je pense savoir d un sa viens
1 soit intel a bloquer l usage de quicksync en passthrough.
2 soit il y a un bug dans les cpu de 11eme et intel ne veut dire pour eviter de les échange au gens.
3 soit il faut avoir une mise a jour du bios.
mai je suis sur que sa ne viens ni de l hyperviseur qui de la carte Mére.
4 je vais renvoyer mon 11700K pour un 10700K qui lui marche très biens en passthrough puisque j ai le 10105 qui lui marche aussi très bien.
j ai remarquer une chose quand on fait des choses spécial avec un pc vaut mieux toujours un CPU qui a 2 ans au minimum on veut le dernier et rien ne marche.
les dernière générations c est bien que pour les neuneu avec windows 11 qui nous découvre des bug.
- « Previous
- 1
- 2
- Next »
