我有两张intel显卡,一张a770 16g,一张DG1。两张一起使用,dg1主要用于推流和录屏。使用上目前没问题。只是显卡的占用率,温度,功耗,时钟频率和占用率这种监测信息显示不准。像是两个显卡信息弄混了。不仅仅驱动自带显示错误,甚至连Intel PresentMon也显示错误。应该是Intel PresentMon读取的也是驱动内的信息。windows任务管理器显示温度和占用率是没问题的。错误如下图。
Hello ouco,
Thank you for posting on the Intel
请注意,我只能用英语支持您。我已使用网络翻译工具来翻译此回复,因此可能会有一些不准确的翻译。
To have a better understanding of the situation, please answer the following questions:
- Did it happen before?
- When did the issue start? Did you notice if it started after an update or change?
- To check your system configuration un, save and attach the report for the following tool Intel® System Support Utility for Windows (SSU), you can find the steps on the link How to get the Intel® System Support Utility Logs on Windows.
Andres P.
谢谢您的回复,这个双intel显卡监测信息识别错误问题是之前所有显卡驱动版本都有,只是我到现在才向官方社区反应此问题。下面是我的电脑SUU信息文档
Hello ouco,
Thank you for your response and all the information provided, that helps me a lot to understand the issue.
I see it is related to Intel® PresentMon. Issues, bugs, and feature requests can be submitted at the GitHub site, and we will be more than glad to help you.
For now, we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
