Hi haibujianjiandandna,
To better assist you and determine the most appropriate resolution, could you please provide the needed details listed below:
- Have you tried rolling back your drivers to check if the issue will persist?
- Have you already tried the latest GPU driver version (32.0.101.6299)?
Source link: Intel® Arc™ & Iris® Xe Graphics - Windows*
- Try rolling back your Windows OS to Windows 10 if the issue will still persist.
Earl E.
My name is George LaCourse (<<<email removed; use PM for private communication>>> ). I have a similar problem to the one listed above. My problem is with the Intel audio system in my Coolby Windows 11 laptop. After installing 24H2 in my system, the operating system no longer sees the Intel audio hardware. The Windows Device Manager sees the Intel audio and says the drivers for it are the current versions, and it is working properly. The operating system can no longer recognize the Intel hardware, so there is no sound.
Microsoft is telling the press that the maker of the audio equipment (Intel) must come up with new drivers to correct this problem.
HELP!!!
Earl E.
Earl E.
