Intel® ARC™ Graphics
3288 Discussions
A750 驱动版本32.0.101.7026
lixunin
接两个屏幕 一个屏幕2k180hz  另外一个1080p 60hz 副屏幕在有显示内容且会动的画面就会导致主屏幕会频繁的闪屏幕,请问一下这个闪屏幕问题是否可以通过更新驱动解决
JeanetteC_Intel
Hello lixunin,
请注意,我只能用英语为您提供帮助。我使用网络翻译工具翻译了这个回复,所以可能有一些不准确的翻译。接下来,我会用英语回答你。
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
1) Is this a new multi-display setup where you first noticed the flickering, or a previously working setup that recently developed this issue?
  • If previously working: What recent changes were made? (hardware additions, display settings, OS updates, driver updates, etc.)
  • If first-time setup: Please proceed to question #2.
2) For Display Configuration:
  • How are your displays/monitors connected?
  • Are they plugged directly into the Intel® Arc™ A750 Graphics card, or through a hub/dock?
  • Which specific ports are being used?
  • Are you using direct cables (HDMI to HDMI, etc.) or adapters?
3) Monitor Details:
  • What are the make and model of your displays/monitors?
  • Please provide a link to their specifications if available.
4) Power Supply:
  • What is your PSU make and model?
Additionally, I highly appreciate you sharing your system configuration so I can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save. *Attach the SSU log file as you reply.
JeanetteC.
