When the GPU is fully under load (228W) and with the default ARC Control fan curve, there are inverted spikes of power usage. I believe that the card is wrongly thermal throttling (the temperature limit is set to 90°C, but the VRAM is at 85°C and the core is at 80°C), and when it's throttling like that, it's for too long, creating those sort of valleys in graphs with the wattage going as low as 90W even though the card is fully under load, and core clocks going as low as 300Mhz. I already did a DDU. Please do not tell me to get out of Windows insider : I'm in the queue to get out of it, and this issue occurs since the latest 4369 drivers, meaning that it's very not likely due to Windows
I have linked screenshots and a SSU
Hello TheWonderfulPie
Thank you for posting on the Intel® ARC™ Graphics Communities. I am sorry you are experiencing thermal throttling issues with your Intel® Arc™ A770 GPU.
I understand that you are already working on getting a stable version of Windows 11 on your system. The latest stable build will be 22621. As the first troubleshooting step, it is necessary to confirm whether the issue happens only on Insider Preview or not. In this case, once you have reinstalled the Operating System, I would advise resetting your BIOS to default settings as well as resetting the Intel® Arc™ Control Software Performance Tab to default settings.
If the issue is confirmed to happen on Windows Build 22621, please monitor the GPU behavior using Intel® Arc™ Control Software and share screenshots if the same behavior is visible from the software.
Hugo O.
Thanks, I will do an update once I will be able to have a stable release without having to reinstall the all the system again, please do not close this thread
Have you been able to test your system behavior with a stable Windows build? Let us know the results.
Hugo O.
I will not forget to reply as soon as I have the stable version, please do not close this thread
Were you able to test if this issue happens in a stable build of the Windows Operating System? Please let us know.
Hugo O.
I hope you are doing fine.
Hugo O.
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
Before closing this thread and in case you still experience this issue, we would like to know how are you pushing the GPU into full load. In case you are using a stress appa, please let us know which ones.
Hugo O.
Thank you for letting us know. We will be doing some testing and checking if the issue can be reproduced from our side. Is there any other setting or step that we need to be aware of in order to try to reproduce this issue? Or, do you just run MSI Kombustor with the Vulkan preset and monitor with MSI Afterburner?
Hugo O.
Thank you for your confirmation. We will be testing this scenario and checking if the same behavior can be reproduced. We will post back once there is an update for you.
Hugo O.
We want to let you know that we tried to replicate this issue but were not able to see such behavior. At his point we would advise that you replace your GPU at your place of purchase as it might be defective, in case you experience issues when processing a warranty replacement, please feel free to contact us directly:
U.S. and Canada: Intel Customer Support
Europe, Middle East, and Africa: Intel Customer Support EMEA
Asia-Pacific: Intel Customer Support APAC
Latin America: Intel Customer Support LAR
We are leaving this thread open so other users can post to see if other users are affected by this exact same issue and share feedback/experience towards a common solution.
Hugo O.
