Intel® ARC™ Graphics
3400 Discussions
ARC A770 16GB Games Crashing Win10/Win11
GameCrash-A770
Hello there,
last week I bought a Intel ARC A770 16 GB.
Installed a fresh Windows 11 with all drivers - (newest bios update).
And Games like: CS2, Rocket League, Hell let loose, Trials Rising are crashing after 2-10 Minutes.
Sometimes i got a BSOD with different stop codes and sometimes the game breaks with the notification "fatal error".
So today i did a new clean install at Windows 10.
First I installed the newest driver - and the lates WHQL Driver. (Deinstalled old driver with DDU)
But nothing changed.. The Games are still crashing after 2-10 Minutes..
Can someone help me?
My Specs:
Intel i9 11900K
MSI Z590 Gaming Plus
32 GB RAM 2400 MHZ
1000 Watt Power Supply
Intel Arc A770
Samsung 990 Pro M.2
Best regards
Tobi
GameCrash-A770
I installed Furmark and stress tested the GPU. At minimal resolution my computer broke down. (I had a 1000 Watt PSU). I heard a buzz in my PSU when the GPU load is getting higher. So today I installed a new PSU - and the Problem is solved! Thanks @DanSun for you help!
DanSun
Make sure you have set up virtual memory You can set the settings as shown in the attached image.
GameCrash-A770
I activate the Option with Virtual Memory - it takes little bit longer till the error or crash will come back but thanks for the reply DanSun
Here is the Error Code from Rocket League after 10 minutes playing, what else can I check???
Name der fehlerhaften Anwendung: RocketLeague.exe, Version: 1.0.10897.0, Zeitstempel: 0x65b4291e
Name des fehlerhaften Moduls: RocketLeague.exe, Version: 1.0.10897.0, Zeitstempel: 0x65b4291e
Ausnahmecode: 0xc0000005
Fehleroffset: 0x0000000000a4abe9
ID des fehlerhaften Prozesses: 0xfac
Startzeit der fehlerhaften Anwendung: 0x01da643b3de6ad61
Pfad der fehlerhaften Anwendung: C:\Program Files (x86)\Steam\steamapps\common\rocketleague\Binaries\Win64\RocketLeague.exe
Pfad des fehlerhaften Moduls: C:\Program Files (x86)\Steam\steamapps\common\rocketleague\Binaries\Win64\RocketLeague.exe
Berichtskennung: c9758d15-8091-4b20-aa53-efd9c3ac06e8
Vollständiger Name des fehlerhaften Pakets:
Anwendungs-ID, die relativ zum fehlerhaften Paket ist
DanSun
I suggest the following method:
1. Update to 5330 driver
2.5330 driver doesn't work, try installing DXVK in the game.
GameCrash-A770
