Intel® ARC™ Graphics
3324 Discussions
ARC B580 run at 3% GPU using in Blender4.4. with 32.0.101.6974WHQL
Sean2025
ARC B580 run at 3% GPU using in Blender4.4. with 32.0.101.6974WHQL. I using oneapi in perference,cycle at GPU.Although it runs better than my 9600X CPU,it is unnormal.
JedG_Intel
Hello Sean2025,
Based on your initial post, it appears that you are using the graphics driver version 32.0.101.6974WHQL which is quite outdated. Could you please try to download the latest driver 32.0.101.7028 and perform a clean installation using DDU.
If you have any questions, please let me know.
Best regards
Jed G.
JedG_Intel
Hi Sean2025,
I wanted to check if you had the chance to review the information I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
garry426milner
If your ARC B580 is only using 3% GPU in Blender 4.4 with OneAPI, it’s likely falling back to CPU or not using the GPU properly.
Sean2025
Thanks for answering,
I think oneapi truly work,because its speed is faster than only by CPU
Sean2025
OK,I would try the latest driver 32.0.101.7029
JedG_Intel
Hello Sean2025,
Thank you for your effort. In case you encounter the same issue, please let me know so we can further troubleshoot.
Best regards
Jed G.
JedG_Intel
Hi Sean2025,
I'm checking to see if you require further assistance. Please let me know so I can proceed accordingly.
Jed G.
JedG_Intel
Hello Sean2025,
Jed G.
