Intel® ARC™ Graphics
3455 Discussions
Acer Predator A770 graphics card 16gb model - dual monitor does not work
JimJ25y62
I was using a 6650XT graphics card and it went dual-monitor no problem. When I installed the drivers, it does not work.
Acer Predator BiFrost Arc A770 OC Graphics Card
Windows 10 [21H2] x64
Driver from intel: gfx_win_101.5084_101.5122
Labels (2)
Hugo_Intel
Hello JimJ25y62
Thank you for posting on the Intel® ARC™ Graphics Communities.
I understand that a dual-display configuration is not working when using your A770 GPU, Could you please let us know more details about the issue? Like, is there no display at all coming from the monitor? Is only one of them working? is this a display corruption issue? Let us know the exact symptoms that you are seeing.
Also, please share with us the following reports to get the system details:
Intel® System Support Utility
Intel Graphics Command Center (Intel GCC)
In addition, let us know the type of connections you are using DP or HDMI, and if you are using any type of video adapter.
Hugo O.
Intel Customer Support Technician,
Hugo_Intel
Hello JimJ25y62
If you are still experiencing this issue, please share with us the information we requested in our previous post so we can further assist you with this problem.
Hugo O.
Hugo_Intel
Hello JimJ25y62
We have not received the information we requested to assist you with this issue so we will proceed to close this thread. If you still require assistance with this problem or need help with any other issue, feel free to open a new topic.
Hugo O.
