Intel® ARC™ Graphics
Arc 750
Dan1867
Is there any pictures and easy explanation as to the 4 ports on the ARC 750. Can I use a HDMI cable on all 4 ports or is there different cable or adapters. I want to put a second monitor on the card?
Jean_Intel
Hello Dan1867,
Thank you for posting on the Intel️® communities. We will be more than glad to help you.
We understand you have opened an Internal support case with us regarding this concern. We will continue to help you through that channel now. We will, therefore, close this community case. Keep in mind that this thread will no longer be monitored by Intel. Thanks for your understanding.
Best regards
Jean O.
