Intel® ARC™ Graphics
3300 討論
Audio not working from Displayport monitors connect to Intel Arc A770 16GB
preetpalS
新手
3,167 檢視
I have an Intel Arc A770 16GB. I am on the Windows Insiders Dev Channel. After the latest update to Windows, audio does not work from the DisplayPort monitors connected to my Intel Arc A770 16GB card. I have been forced to connect the DisplayPort connectors to an older NVidia 1650 super and the onboard graphics from my CPU (AMD Ryzen 7600X) in order to get sound working. This issue is specific to the Intel Arc card. Sound used to work prior to the Windows update. Please note that I installed the latest Intel Arc Drivers 5330 and 5194 on this version of Windows and sound does not work through the DisplayPort monitors (I did not test HDMI).
Windows specifications
Edition Windows 11 Pro for Workstations
Version 24H2
Installed on ‎2024-‎02-‎12
OS build 26052.1100
Experience Windows Feature Experience Pack 1000.26052.1100.0
標籤 (1)
0 積分
1 解決方案
preetpalS
新手
2,736 檢視
The issue went away with OS build: 26080.1201
I also have the current driver version of 31.0.101.5333 for my A770 graphics card.
在原始文章中檢視解決方案
7 回應
Joseph64
初學者
3,121 檢視
I also have lost sound with driver 5330 hdmi
RamyerM_Intel
主席
3,061 檢視
Hello preetpalS,
Thank you for posting in the community.
For the Windows Insider Program all feedback (including issues) must be submitted directly to Microsoft, even if they impact specific 3rd party components. Refer to https://www.microsoft.com/en-us/windowsinsider/feedback
@Joseph64 are you experiencing this issue on the latest stable Windows 11 release? (i.e. 23H2). If yes, please provide us with the Intel SSU report so we can check details about your system configuration such as Graphics driver version and potential errors logged by the OS.
Also please let me know the model of the display(s) and if there is any other component used in the configuration (per example: DP/HDMI adapters, AV receivers, etc).
Ramyer M.
preetpalS
新手
3,008 檢視
This has already been reported to the Windows insider program. I will update this forum post if the issue is fixed in a future Windows update or future Intel Arc driver.
preetpalS
新手
3,008 檢視
For my configuration, there is only a DisplayPort Cable (no adapters or anything else) between the graphics card and the monitor.
RamyerM_Intel
主席
2,950 檢視
Hello preetpalS,
That is indeed a good way to foster our community. For now, it is best to wait on the update from Windows Insider Program.
Thank you for contacting Intel.
Ramyer M.
preetpalS
新手
2,737 檢視
YesGang
初學者
394 檢視
 I  have the same problem , my  monitor which connect  to my PC with DP can not sound, and my pc cann't notice the monitor as  a  vidio sendout.
   While  i  haven't changed  my display card from GTX1080 to A750, there is no problems,but  i can 't  make my monitor sound agian.
回覆
