During the editing of the video, blue screens of death began to appear in the adobe premiere. I'm attaching a photo. Such cases occurred on the following drivers - 32.0.101.6790 . Previously, I used the drivers - 6257. 6257 were the most stable for editing, but they had a problem with simultaneous work in the primer and aftereffects through an adobe media link. the image was constantly disappearing and aftereffects gave a video card driver error. So I updated to newer drivers.
The 6790 drivers seem particularly buggy with Adobe apps. I tested them on my B760 board with an A770 and got constant crashes. Switched to 6500 and things are mostly stable again, even if dynamic link is still a little flaky. Adobe and Intel really need to sync better on compatibility testing.
However, the fact that Intel is trying to fix these bugs and release more stable drivers makes me optimistic, so it is important to describe your problems.
@Maxowen55 kindly submit a separate thread so we can further assist you and get back to you.
Hi @AndrewUA,
- Please provide the SSU log report and share it here so I can review your system's configuration.
 - Could you please let me know which version of the application you are currently using?
 - Have you previously performed a clean installation of the graphics driver, before using either an older or the latest version?
 - . When did the issue first occur?
 - Have you made any software or hardware changes to the system recently?
 - What troubleshooting steps have you tried so far aside from driver updates?
 - Have you noticed any signs of overheating in the system?
Warm regards,
Randy T.
Hello, thank you for your reply. For now, I'm back to the 6257 driver, as the newer drivers started to cause blue screens to occur very frequently when working in Adobe Premier Pro.
-- I've attached the file. - Could you please let me know which version of the application you are currently using?
--25.2.3 - official, downloaded through the Creative Cloud. - Have you previously performed a clean installation of the graphics driver, before using either an older or the latest version?
--I updated the new version of the drivers through Intel Graphics Software. I went back to the old version of the drivers with uninstallation via DDU. - . When did the issue first occur?
-- The first time this error occurred was after updating the drivers to version 6790. - Have you made any software or hardware changes to the system recently?
-- No, I just updated the driver. - What troubleshooting steps have you tried so far aside from driver updates?
-- I went back to the old drivers and the problem disappeared. But in the old drivers, the adobe dynamic link does not work correctly. With the new drivers, there was no problem with the adobe dynamic link. - Have you noticed any signs of overheating in the system?
-- I haven't noticed any signs of overheating, and the weather is quite cool at 19 degrees Celsius.
Hi @AndrewUA,
Thank you for sharing this information. I will begin investigating the issue and attempt to replicate it on our end. I'll post an update here or notify you directly once there are any developments. If I need further details, I'll reach out to you here. I appreciate your patience as I work on this matter.
Warm regards,
Randy T.
Hi @AndrewUA,
I want to follow up some points. To assist you further with the issue you're experiencing, we kindly request some additional information and files. Your cooperation will help us analyze and resolve the problem more effectively.
- Have you tried installing the latest graphics driver version 32.0.101.6793 using Display Driver Uninstaller (DDU)? If not, we recommend doing so to ensure optimal performance.
 - Could you please share the steps you take to recreate the issue? This will help us understand the context and identify potential solutions.
 - If possible, could you share the project files where the issue occurs? You can send them privately via email to ensure confidentiality.
 - We also request that you generate a kernel or complete crash dump and share it with us for detailed analysis.
Please let us know if you have any questions or need further guidance on any of the requests.
Warm regards,
Randy T.
Thank you for your reply.
Yes, today I installed the drivers 6793 and tested them (Used DDU). The problem with the VIDEO_TDR_FAILURE error hasn't disappeared, but the computer has started to restart more often without the blue screen of death. - Could you please share the steps you take to recreate the issue? This will help us understand the context and identify potential solutions.
_____
This happens during the playback of a video in the adobe premiere app. And it happens at a completely random moment, regardless of the type of video file or project. It usually happens when I'm watching a video and move the timeline cursor to another location. The computer freezes for 5-10 seconds and restarts, or shows a blue screen of death. - If possible, could you share the project files where the issue occurs? You can send them privately via email to ensure confidentiality.
This does not depend on the project, it happens in absolutely all projects that I open for work. - We also request that you generate a kernel or complete crash dump and share it with us for detailed analysis.
____
The file is available at this link - https://fex.net/uk/s/rybe4f1
Thank you for trying to solve this problem.
Yes, you are right. Sometimes it just reboots, sometimes with a blue screen of death.
Yes, I use the old driver 6257 , which has better stability in Adobe premiere pro.
Последний драйвер установлен! Проблема возникает только в некоторых играх!!!
The problem is the same with any drivers!
The latest driver is installed! The problem occurs only in some games!!!
@Andrey1970 kindly submit a separate thread so we can further assist you and get back to you.
Hi @AndrewUA,
Thank you for sharing this information. Please allow me some time to further investigate the issue and replicate it on our end using the details you've provided. I will post an update here once I have completed my analysis. I appreciate your patience as I work on resolving this matter.
Warm regards,
Randy T.
Thank you, I hope you will be able to solve this problem. I'm now back on the 6257 driver - no blue screen for a whole day of work.
Yes, unfortunately Intel has removed the old drivers from the site for some reason.
Do you also have problems with Adobe Premiere?
Drivers are available here. - https://fex.net/uk/s/cnlkk0s  The only thing is that the adobe dynamics link works very poorly and there may be problems with the sound during video editing, but in general they work stably.
