Intel® ARC™ Graphics
3318 Discussions
B580 Zenless Zone Zero Objects/Textures popping in
Nakano44
Hello everyone,
i've been using my B580 for a few days now had little issues so far, but i just noticed this issue where were textures in Zenless Zone Zero are popping in when moving through areas. It's really bad in the Areas "Sixth Street" and "Lumina Square" (also some fighting arenas) .
Maybe some one has an idea what's causing this or has the same Issue. On my old set up with an RX 5700xt it worked fine. I already googled a little bit and found a video of Zenless Zone Zero with the B580+R5 5600 and saw similar behavior (did not find anything else).
Other Hoyoverse games like Honkai Star Rail seem fine (no popping of objects). I also tested a more demanding game (Dying Light 2) with no issues. Hard to tell if it the game or the driver. Maybe some one has some more insight on this.
The overall performance is great (about 100-120 FPS in mentioned areas), no issues there, but the popping in of object and textures seems to be some kind of problem between driver an game.
I attached some videos of the issue and pictures of the settings.
System information:
OS: Windows 11 Pro 24H2
Driver: Intel Graphics Driver 32.0.101.6449
CPU: Intel Core Ultra 5 245K
GPU: Asrock Z890 Pro RS (most recent bios)
RAM: Kingston 32 GB DDR-5 6000 CL30 (XMP on)
MB: Asrock B580 Challenger (re-Bar on)
SSD: Lexar NM790 SSD 2TB
PSU: Thermaltake TT Toughpower GT 750 W
Mike_Intel
Hello Akaiaki,
  1. Have you tried to check with the game manufacturers if they have an update for the game since no issues with other games?
  2. Are you using an Intel brand Arc graphics?
  3. What is your game launcher?
Michael L.
Nakano44
thanks for your message.
For your questions:
1. Yes, I did open a support ticket with the game developers. Currently there is no update available. But they acknowledged the issue and "forwarded it to the relevant Team", what ever that means. No update since. I also found out, other people have the same issue with their b580 in Zenles Zone Zero.
2. No, I use the Asrock Challanger OC B580.
3. I use the HoYoPlay game launcher, their first party launcher.
Do you need anything else? I'll always try to answer as fast as I can.
Kind regards
Mike_Intel
Hello Akaiaki,
Thank you for the update.
Please try install the latest driver that we have using DDU.
Here is the link of the step and the link for the latest driver.
https://www.intel.com/content/www/us/en/support/articles/000091878/graphics.html
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
Michael L.
Mike_Intel
Hello Akaiaki,
Michael L.
Nakano44
sorry for the late reply, i did not get a notification per mailfor some reason.
Anyways, i tried a DDU. Actually i tried it 2 times. Sadly i did not work. The issue still remains.
KirinI
@Mike_Intel
I have a similar issue, but the difference lies in the platform and the graphics card model I am using.
I have already tried reinstalling the system and the graphics card driver, and I have also reported it to Mihoyo.
Regardless of whether I use -force-d3d12 as a launch parameter, the game crashes.
When attempting to clear the levels of  `Notorious Huntand` -> `Sacrifice - Bringer` and `Hollow Zero` -> `Lost Void` -> `Battlefront Purge` -> `Difficulty V` -> the last level ( the same bosses and maps as upon ), there is almost a 100% chance of it crashing.
Win11 Professional 24H2 26100.2894
AMD Ryzen 7 5700X3D
Aorus X570 Elite WIFI
DDR4 3200MHz 16G * 2 + DDR4 3200MHz 32G * 1 ( XMP )
Intel Arc A770 16G Resizable BAR enable
Intel Graphics Driver 32.0.101.6458
Mike_Intel
Hello Akaiaki,
Please help generate the latest SSU logs of your system after the update for me to further check this issue.
Kindly follow the steps in the link below:
@KirinI
If you need assistance, please create a new thread for us to assist you on your own thread and gather the details of your systems.
Michael L.
Mike_Intel
Hello Akaiaki,
I am just making a follow up on the SSU that I requested.
Michael L.
Nakano44
sorry for the late answer. My pc was in a repair shop beacause I had some issue with installing drivers an the windows device manager.
I attached the text file, which i got from running the SSU. I hope that helpes, because i still have the issue.
kind regards
Akaiaki
ChaoticFriedRice
Just wanted to second this, I have also experienced this issue, especially while roaming the overworld. In addition I am also experiencing a bug where the game will not switch the texture quality (stuck on low resolution textures) regardless of what I set it at. I am also using the intel arc B580 Challenger OC model
Mike_Intel
Hello Akaiaki,
Upon initial checking of the SSU, you are not using the latest Graphic driver. The latest that we have is 32.0.101.6262
Please update the driver and check if that will help. You may download the driver in the link below:
@ChaoticFriedRice
Michael L.
Nakano44
Yeah,
i updated it after doing this SSU thing. The new driver did not change anything. Issue stays the same.
Mike_Intel
Hello Akaiaki,
Please help generate a new set of SSU logs that shows the latest driver for me to have this investigated.
Michael L.
Nakano44
Here is the SSU on the new version. Let me know if you need anything else.
Mike_Intel
Hello Akaiaki,
I will do further research on this matter and post the response on this thread once it is available.
Thank you very much for your patience and understanding!
Michael L.
ProDUO
I’ve also encountered this issue. I’ve tried many methods to resolve it, but none of them worked, which is really a bit frustrating. I hope it can be resolved as soon as possible.
Mike_Intel
Hello Akaiaki,
I hope this message find you well.
I just want to update you that we were able to replicate the issue of objects popping in as it is originally described on this thread.
Once there is an update on our findings and if we have recommendations, I will post it here however there is no ETA for now.
If you have questions, please let us know.
@ProDUO
Michael L.
DropTables
I also had this problem as described in the opening message with my B580 Steel Legend, but after updating the game to the 1.6 patch (released on March 13 2025), and also upgrading the GPU driver from 32.0.101.6458/32.0.101.6257 to 32.0.101.6647, it seems the pop-in problem is resolved. For example the "Sixth Street" in-game area has the pop-in issue completely resolved. Uncertain whether it was the game patch or the driver update that did the trick, but it's worth trying, for anyone else experiencing this issue.
Tested with:
OS: Microsoft Windows 11 Home (x64), Version 24H2, Build 26100.3476
CPU: AMD Ryzen 5 7600
GPU: ASRock Intel Arc B580 Steel Legend 12GB
RAM: Kingston FURY Beast DDR5-6000 - 64GB CL30 (EXPO 1)
NormanS_Intel
Hello @Akaiakin, @ProDUO and @DropTables
Thank you for your patience. Our investigation has determined that the issue is resolved with the combination of Graphics Driver 32.0.101.6734 and the latest game update. Please try using this version or a newer one, and share the results with us. Before proceeding with the graphics driver update to the latest version, kindly ensure that you perform a clean installation using DDU. For further details, please refer to our article titled "Clean Installation of Intel® Graphics Drivers in Windows*"
We sincerely apologize for the delay, as it was essential for us to perform comprehensive testing.
Norman S.
NormanS_Intel
Hello Akaiaki,
I hope you had the chance to review the information I posted. Please let me know at your earliest convenience so that we can determine the best course of action to efficiently resolve this matter.
Norman S.
