Intel® ARC™ Graphics
3446 Discussions
BF6 poor performance
JazzC8
I have a B580, and i'm getting 40 -60 fps 1080p in multiplayer all settings low.
System is as follows:
CPU: 5700X3D
RAM: 3600mhz CL16 32Gb
MOBO: MSI MAG B550 Tomahawk
PSU: EVGA SuperNOVA 850 G+ Gold
Storage: OS is on a 500gb Samsun 980 Pro PCie 4.0x4 NVMe
Game is installed on a  TEAMGROUP MP33 2 TB PCie 3.0x4 NVMe
GPU is pegged at 99%; if i use upscaling, still no change in fps. I also have noticed that the power is around 70w and will only go higher in the menus??? I checked the IGCC and did basic tuning to have the slider for power go max, same as temp. Temp never goes over 60c. CPU is never pegged out. I have used the Alt enter and it does seem to kinda work???. Start the game in windowed mode then Alt enter into full screen.
Other things I have checked is the PCie link power state is off/max power (not power saving) Also checked the PCie reported by GPUz shows 4 x 8 lanes.
JedG_Intel
Hello JazzC8,
To assist you effectively, please share the information below.
1. Is the issue isolated to a specific game?
2. Is ReBar enabled?
3. Does the Alt+Enter workaround consistently improve performance, or just sometimes?
4. Have you tried the B580 in a different PCIe slot or different system?
Additionally, to have a better understanding of your system configuration and components please generate a complete copy of the System Support Utility (SSU) report. Please follow instructions here and send the report - How to get the Intel® System Support Utility Logs on Windows*
Best regards
Jed G.
JazzC8
Only BF6, Rebar is enabled. Yes Alt enter seems to work consistently. I have not tried a different Pcie as the other ones are 3 x 16. Ill work on getting a SSU
JazzC8
Attached is the SSU
OliviaHazel_W
1. GPU power limit or bugged driver profile
  • You mentioned it only draws ~70 W and spikes higher in menus — that’s a big red flag.
    • A properly functioning B580 GPU (Intel Arc A580) should easily hit 175–185 W under load.
  • Open Intel Arc Control → Performance → Telemetry and confirm:
    • Power limit slider = 100%
    • GPU utilization = 99%
    • GPU clocks = around 2200–2400 MHz under load
  • If the clocks are much lower (like 1100–1500 MHz), it’s power or driver-related throttling.
2. Reinstall or clean the driver
  • Use DDU (Display Driver Uninstaller) in Safe Mode to remove all Intel GPU drivers.
  • Then reinstall the latest Intel Arc driver (WHQL) directly from Intel’s website — not Windows Update.
3. Resizable BAR (ReBAR)
  • Arc cards depend heavily on ReBAR.
    • Check in GPU-Z → Advanced → PCIe Resizable BAR — it must say Enabled.
    • If it’s “Disabled” or “Unsupported,” enable it in BIOS (Advanced → PCIe Settings → Resizable BAR → Enabled).
4. BIOS + chipset drivers
  • Update to the latest MSI B550 Tomahawk BIOS (especially those with AGESA 1.2.0.x updates for ReBAR).
  • Reinstall the latest AMD chipset drivers from AMD’s official page — not MSI’s.
5. Power mode in Windows
  • Set to Ultimate Performance (or High Performance).
    • Run powercfg.cpl → select “Ultimate Performance.”
    • Disable Windows Game Mode just for testing.
6. Background apps
  • Make sure Arc Control, MSI Center, or Afterburner aren’t fighting each other. Close everything except the game.
7. Test in another game
  • Run something like 3DMark Time Spy or a consistent benchmark (Cyberpunk 2077, Forza Horizon 5).
    • If power usage is still stuck ~70 W and FPS scales poorly → definite GPU issue.
JazzC8
As I mentioned in the first comment, I have the power slider for the gpu set to 100 same as temp. The clocks are higher then 2400. I have tried it in default tuning and my custum tuning at 3.2. I have performed a DDU and rebar is enabled. chipset is updated and bios is only 3 versions back. It has 1.2 agesa. I leave the windows power mode on balanced as recommended by AMD for X3D cpus, I instead have maximum performance selected in the GPU preference selection in the graphics settings in windows for applications. I have seen other Arc users commenting that their have the same issue and the alt enter is what they have been using. So Ive accepted that its a intel driver issue with the game.
