Intel® Arc™ Discrete Graphics
3580 Discussions
Blocky tree with A770-16LE
Saabjock
https://youtu.be/9hG0rXw5RQw
https://youtu.be/vF46aeTlbmY
The two links represent what is being seen/generated on screen when running Reiza Studios Automobilista 2 simracing title at Mugello circuit.
This has occurred with every Intel ARC driver to date... including the currently loaded 32.0.101.6078
The computer specifications are MSI B450 Gaming Pro Carbon AC motherboard (AM4) with BIOS version 7B85v1H4
B450 GAMING PRO CARBON AC (MS-7B85) V1.H4 BIOS Release
1. This is AMI BIOS release
2. This BIOS fixes the following problem of the previous version:
- AGESA ComboAm4v2PI 1.2.0.Cc update.
- Added security issue of SMM Lock Bypass uCode fix aka “Sinkclose”.
3. 2024/09/25
-----------------------------------------------------------------------------------------------Winver 2024-09-27 221854.png
Operating System: Windows 11 Pro 64-bit (10.0, Build 22631) (22621.ni_release.220506-1250)
Language: English (Regional Setting: English)
System Manufacturer: Micro-Star International Co., Ltd.
System Model: MS-7B85
BIOS: 1.H4 (type: UEFI)
Processor: AMD Ryzen 7 5800X3D 8-Core Processor (16 CPUs), ~3.4GHz
Memory: 32768MB RAM
Available OS Memory: 32694MB RAM
Page File: 11943MB used, 25613MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: 1.6.1
DxDiag Version: 10.00.22621.3527 64bit Unicode
JeanetteC_Intel
Hello Saabjock,
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
1) Can you re-share the links you initially provided, so I can see the issue you are reporting? It is currently not accessible.
2) When you say "blocky tree", does it look like it's pixelated of some sort? *For graphics corruption (for example artifacts, texture corruption, or lighting glitches) please use Intel Arc Control to capture screenshots or a video showing the bug.
3) Is the game previously working and only have the issue recently?
I will wait for your reply so I can check further.
Jeanette C.
Saabjock
Issue resolved
JeanetteC_Intel
Hi Saabjock,
I'll take note of this and will proceed with closing this thread.
If you need any additional information, please submit a new question as this thread will no longer be monitored.” then, close the case.
Sincerely,
JeanetteC.
