Intel® ARC™ Graphics
3418 Discussions
Bug Report: Arc A770M - Windows lose position/size after lock/unlock (Driver 32.0.101.6793)
Setox
Issue Summary
Intel Arc A770M Graphics driver version 32.0.101.6793 causes all application windows to lose their size and position after system lock/unlock operations, resulting in windows being compressed and relocated to the top-left corner of the screen.
Affected Hardware
  • GPU: Intel Arc A770M Graphics (16 GB VRAM, Discrete)
  • CPU: 12th Gen Intel Core i7-12700H
  • Secondary GPU: Intel Iris Xe Graphics (Integrated, 16 GB Shared)
  • Driver Version: 32.0.101.6793 (WHQL)
  • Intel Graphics Software Version: 25.14.130.21
Problem Description
When the system is locked (either manually via Win+L or automatically due to inactivity timeout) and subsequently unlocked, all open application windows experience the following issues:
  1. Window Size Reset: All windows lose their custom dimensions and revert to minimal size
  2. Position Reset: All windows relocate to the top-left corner of the primary display
  3. Layout Destruction: Multi-window workflows are completely disrupted
  4. Persistence: The issue affects all types of applications (browsers, file explorers, text editors, etc.)
  5. Clean install and upgrade drivers doesn't help at all. The problem exists for a months and started to occurrence at January this year I guess
JeanetteC_Intel
Hello Setox
I've tested both versions 32.0.101.6881 and 32.0.101.6913, and neither shows any issues with positioning and size after locking and unlocking the system.
Please perform a clean installation of the latest Intel® Graphics Driver 32.0.101.6913 (WHQL Certified) using the Display Driver Uninstaller (DDU). If the problem continues, I strongly recommend reaching out to your system manufacturer support team for further assistance, as there may be an incompatible Intel graphics driver installed on your system.
Best regards
JeanetteC.
JeanetteC_Intel
Hello Setox,
Please proceed with clean installation of the latest driver version 32.0.101.6874 (WHQL Certified) using the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver.
Monitor and check if the issue persists after the steps above. If you do, please contact your system manufacturer support team to get assistance on updating the latest BIOS (0063)
Share a new SSU log file after the steps above, if the issue still persists.
I hope to hearing from you soon.
JeanetteC.
Intel Customer Suppot
JeanetteC_Intel
Hello Setox,
Let us know if you have any questions.
JeanetteC.
Setox
Hi Jeanette, I hope you are doing well
Yes, I went through your instructions and the situation seems better
Let's wait until Monday. I'll try to use my PC more this weekend and get back to you with feedback
Happy Friday!
Setox
Hi Jeanette,
unfortunately, the problem still exists
I've attached fresh logs, could you please check them?
Thank you
JeanetteC_Intel
Hello Setox,
From the last recommended driver version 32.0.101.6874 (WHQL Certified), we have 2 new drivers available on our Download Center. Please proceed with a clean installation using the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver
Let me know how it goes.
JeanetteC.
JeanetteC_Intel
 Hello Setox,
JeanetteC.
Setox
Hi @JeanetteC_Intel unfourtuanaly the problem still exists on 32.0.101.6881
JeanetteC_Intel
Hello Setox
I will look into this internally and provide an update as soon as it is available.
Best regards
JeanetteC.
JeanetteC_Intel
Hello Setox
Best regards
JeanetteC.
Setox
Hi Jeanette, I can't reproduce the problem on 32.0.101.6913
Thank you for assistance
JeanetteC_Intel
Hello Setox,
Thank you for providing this update. I'm pleased to hear that the issue is not occurring with version 32.0.101.6913. I will go ahead and close this thread now.
If you need assistance in the future, please feel free to reach out by submitting a new question, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
