Using a770 should be 400fps I am at low settings
I am getting from 50-150fps
my old laptop 1060gtx does a better job at running the game
why did I spend $1600 on a nuc12 serpent canyon for this type of experince??
Hi @Tonicstyle
Thank you for posting on the Intel® communities. I'm sorry for the inconvenience this might have caused you. In order to assist you can you please help us with the following information:
- Download and install the Intel
System Support Utility (Intel SSU): https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html? Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". Click on "Next", save the report and attach it to your response.
- Please run a graphics report following this article https://www.intel.com/content/www/us/en/support/articles/000005848/graphics.html especially Intel Graphics Command Center (Intel GCC)
Carlos L.
Hey Dude,
ARC cards do not have native DX9 support, they use a translation layer to convert DX9 call to DX12. This does have a hit to performance. Intel has stated they are working on a back catalogue of older games as there team has time. In titles running under the newer DX12 and Vulcan APIs you should have a better experience.
However what resolution where playing the game at? My experience only shows frame rates that low at 4K High settings. The new driver released Nov 18th ending in 3802 may help. What CPU is in your NUC? Can you pop its model number in the forum so we can checks its full specs to possibly identify your issue?
My Average FPS at high settings at different resolutions are:
1080P 320FPS
1440P 245FPS
2160P 129FPS
Afterburner output for further comparison.
1080 - High Settings- ARC A770
23-11-2022, 20:17:57 csgo.exe benchmark completed, 31247 frames rendered in 98.141 s
Average framerate : 318.3 FPS
Minimum framerate : 53.4 FPS
Maximum framerate : 480.9 FPS
1% low framerate : 57.0 FPS
0.1% low framerate : 51.3 FPS
23-11-2022, 20:19:53 csgo.exe benchmark completed, 32053 frames rendered in 99.766 s
Average framerate : 321.2 FPS
Minimum framerate : 54.6 FPS
Maximum framerate : 477.7 FPS
1% low framerate : 57.8 FPS
0.1% low framerate : 51.6 FPS
23-11-2022, 20:21:48 csgo.exe benchmark completed, 31806 frames rendered in 99.406 s
Average framerate : 319.9 FPS
Minimum framerate : 54.3 FPS
Maximum framerate : 472.9 FPS
1% low framerate : 57.6 FPS
0.1% low framerate : 51.8 FPS
1440 - High Settings - ARC A770
23-11-2022, 20:09:00 csgo.exe benchmark completed, 24019 frames rendered in 98.657 s
Average framerate : 243.4 FPS
Minimum framerate : 34.7 FPS
Maximum framerate : 351.9 FPS
1% low framerate : 34.6 FPS
0.1% low framerate : 20.7 FPS
23-11-2022, 20:11:06 csgo.exe benchmark completed, 24728 frames rendered in 100.625 s
Average framerate : 245.7 FPS
Minimum framerate : 35.1 FPS
Maximum framerate : 358.6 FPS
1% low framerate : 36.8 FPS
0.1% low framerate : 33.9 FPS
23-11-2022, 20:13:01 csgo.exe benchmark completed, 24521 frames rendered in 100.031 s
Average framerate : 245.1 FPS
Minimum framerate : 34.5 FPS
Maximum framerate : 355.9 FPS
1% low framerate : 36.4 FPS
0.1% low framerate : 33.4 FPS
2160 - High Settings- ARC A770
23-11-2022, 20:26:28 csgo.exe benchmark completed, 12754 frames rendered in 99.078 s
Average framerate : 128.7 FPS
Minimum framerate : 18.3 FPS
Maximum framerate : 187.9 FPS
1% low framerate : 19.4 FPS
0.1% low framerate : 17.4 FPS
23-11-2022, 20:28:28 csgo.exe benchmark completed, 12926 frames rendered in 99.766 s
Average framerate : 129.5 FPS
Minimum framerate : 18.2 FPS
Maximum framerate : 188.0 FPS
1% low framerate : 18.9 FPS
0.1% low framerate : 17.5 FPS
23-11-2022, 20:30:24 csgo.exe benchmark completed, 12844 frames rendered in 99.282 s
Average framerate : 129.3 FPS
Minimum framerate : 18.5 FPS
Maximum framerate : 188.3 FPS
1% low framerate : 19.3 FPS
0.1% low framerate : 18.0 FPS
Hello @Tonicstyle
Carlos L.
Hello @Tonicstyle
Carlos L.
