Intel® ARC™ Graphics
3429 Discussions
Can't Turn off Power Saving mode
Qurashi
Gradients are not well-displayed. I can't control the brightness. I have a problem with opening blender, it always says it requires a graphics card and driver with support for OpenGL 3.3.
Everything used to work fine before Windows update. I think it's because power-saving mode couldn't turn it off from the Command Center. I tried uninstalling it, which worked for a while but returned to the same problem later.
I can't reinstall the newest version of Intel iris graphics it always says something went wrong. I also can't reinstall the Command Centre It says something went wrong from their end. I tried different solutions given on the internet, but none worked.
Processor:12th Gen Intel(R) Core(TM) i7-1255U 1.70 GHz
RyanFeeko
New Contributor II
Hey @Qurashi ,
Would you be able to confirm things below:
1- Power-saving you refer to Windows OS feature is it?
2- Have you tried to perform the all updates (eg: drivers etc) through Windows Update?
3- Power drain few time still no go?
This could be new updates of windows have some issue. Lets figure it out.
Qurashi
1- no, I meant Intel Graphics Power Savings
2-yes
3-it went
RyanFeeko
New Contributor II
@Qurashi , thanks for the info.
have you try below steps, i know intel got the article bout this:
https://www.intel.com/content/www/us/en/support/articles/000092564/graphics.html
