Intel® ARC™ Graphics
3294 Discusiones
DirectX 12 Red Dead Redemption 2 problems when activating 144Hz and under FPS 50 to 60 FPS
addelucas123
Nuevo Colaborador II
3.196 Vistas
Good morning, I'm David once again, at that height you're never going to fix the problem with DirectX 12 Red Dead Redemption 2,
1. Run Red Dead Redemption 2
2. Change from Vulkan to DirectX 12
3. When I want to put the 144Hz it doesn't apply it stays 50Hz
4. Performance ranges from 50 to 60 FPS 1920x1080
Everything is updated, even the BIOS , but keep in mind that the BIOS does not improve performance and stability etc.
https://youtu.be/1BUr3W8iCg0?si=Te7Q-DunndN0-EfF
Etiquetas (3)
0 kudos
5 Respuestas
VonM_Intel
Moderador
3.095 Vistas
Hi, addelucas123.
Thank you for posting in our Community.
We acknowledge your feedback and want to assure you that we are actively investigating the issue you've encountered. In the meantime, we'd like to share an article with you that may provide some insights. You can find more information about this issue in the following article: [When in full screen with game Red Dead Redemption 2 with Intel® Arc™ Graphics, frames per second (FPS) turns down to 1 in performance.]. We appreciate your patience as we work to address this matter.
Have a nice day!
Von M.
addelucas123
2.996 Vistas
Well, I'm sending it to you here, the video of RDR2 with the problem I'm having, and please tell me something as soon as possible, thank you
https://www.youtube.com/watch?v=H5KDNP9ElKk&ab_channel=DavidPradosDeLucas
NormanS_Intel
Moderador
2.732 Vistas
Hello addelucas123
Thank you for sharing the video. I wanted to let you know that we are currently addressing the DirectX12 issue and will keep you updated in this thread as soon as we have more information.
Norman S.
addelucas123
2.728 Vistas
Okay, and I want to comment that you tell him to double the performance in DirectX 12 Intel Arc A770 that surpasses RTX 3060 TI double X2 a push
NormanS_Intel
Moderador
2.516 Vistas
Hello addelucas123,
I know this issue has taken time under investigation so I thank you for your patience. Our driver development team is recommending playing Red Dead Redemption 2 on Vulkan API for the best experience on Intel Arc A-Series GPU. As for this issue with DirectX 12, our priority is to target the most popular games and apps to focus our efforts on providing a high-quality, stable experience for the broadest set of users. We will continue to improve our software performance and compatibility throughout 2024 and beyond. While we can’t accommodate your request at this time, please watch this When in Full Screen. Red Dead Redemption 2* Drops to 1 Frame per Second (FPS) on Intel® Arc™ Graphics article on our website for any possible changes to this situation.
We understand this may not be the update you were hoping for. However, please rest assured that every post is documented and acknowledged.
I will now close this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Norman S.
Responder
