Intel® ARC™ Graphics
3452 Discussions
Disappointment
t4h41999
My Intel Arc A750 graphics card, which I bought as my first graphics card with great enthusiasm and hopes, has problems in most games. For example, ‘Wrap House Simulator’, ‘Farming Simulator 22’, ‘Dark Hours’, ‘Fernbus Simulator’, ‘FC 25’, and finally ‘CS 2’ recently, both fps drop and stuttering have become frequent in CS 2. A huge fps drop in Fernbus Simulator (at medium-low graphics settings).10-15 minutes of stuttering in Farming Simulator 22 when I first entered the game. In Wrap House Simulator, while my friends using RTX and GTX get 180 fps, I get 60-70 fps, this is the case in Dark Hours.FC 25 has been high fps in the game since the first day I bought it, but it feels like it's hanging, I'm really extremely dissatisfied.I'm doing all driver updates day by day, maybe the problems will be fixed, but the problems are increasing.It really upset me that my first video card I bought was a disappointment.
UnaSalusVictis
just a suggestion, ddu and install the latest drivers, if its still giving you problems, try installing an older driver you know was working well with the games, not so long ago a major update came to the drivers thats caused problems for some people, not everybody but enough people to make it clear somethings not quite right..
also, any of those games that are dx11 or older, try dxvk-gplasync.
my a770 i can confirm a few of those games (the ones i own) like farming sim 22 seems to run fine for me on current drivers, but i did a ddu not so long ago due to other issues that prob had alot to do with upgrading from the old drivers to the new "improved" drivers..
i do need dxvk-gplasync at times..
this is just a re-pack of the dxvk files with a config file that enabled async shading(helps with alot of older games from my exp, even on nvidia/amd cards)
another thing to check, make sure your cpu isnt throttling for some reason... buddy of mine thought his arc card was the problem recenty and turned out his cpu was failing to hold full clocks... had to rma it... PITA but... yeah... makes me glad im on an older platform ot k nown for alot of degredation issues... heh.... a 10900x at 5.2 aint bad.. heh..
