- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Ryzen 7 2700X
MSI X570-A Pro
16gb ram
Windows 11 Pro
24H2
26100.2605 (build)
Corsair RM1000 psu
Put my computer to sleep, turn it on the next day, no display.
Hold the power button down to shut it off, then back on, no display.
Re-seating might fix it? (sometimes does, other times doesn't)
Taking out the bios battery might help? Hard to tell.
Running latest BIOS 7C37vHP1(Beta version)
In the setup instructions it says to disable "Legacy Mode", I only see "Legacy USB", is that it?
One thing I can tell is that if I hear the fans from the GPU start before the rest of my fans, that's generally a good sign. If all of the fans start at the same time, then no display for certain.
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi MRbermudez,
Thank you for posting in the Community!
Please share more details about the issue so I can assist you effectively.
Can you describe the issue more to us?
Did you do recent changes with the system?
Have you performed other troubleshooting steps?
Please make sure you provide the following basic information when reporting a bug:
- What is the graphics driver you are using?
- Confirm you are using the latest WHQL graphics driver available (let us know the exact driver version you are using).
- A clean driver installation using DDU in safe mode is recommended. Follow this link for instructions.
- You could also test using the latest non-WHQL driver. This driver goes through all Intel quality assurance processes and is safe to use for evaluation.
Dean R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi MRbermudez,
Dean R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi MRbermudez,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
