Intel® Arc™ Discrete Graphics
4122 Discussions
Driver \Driver\WUDFRd failed to load.Status: 0xC0000365
LongSir
Hello, I would like to ask, my computer has been popping up an error in the system log since last year
Device: PCI\VEN_8086&DEV_A71D&SUBSYS_380717AA&REV_01\3&11583659&0&20
Status: 0xC0000365
Then I found the device according to Device is
Intel(R) Innovation Platform Framework Processor Participant
I upgraded the chipset driver provided by Lenovo but it didn't work.
When this error occurs, my computer will suddenly freeze, that is, the screen freezes, and then automatically restart.The system's BugCheck shows that it is caused by the 0x00000116 error code. I also checked the dmp file generated by the system.
The computer has restarted from a bugcheck:0x00000116 (0xffffba0a5c7dc460, 0xfffff8032ada8a70, 0xffffffffc000009a, 0x0000000000000004)。The dumped data has been saved in: C:\WINDOWS\Minidump\110724-11500-01.dmp。Report ID: 45491d2f-bcc2-42ac-9071-ad808f9a17e1。
SYMBOL_NAME:  nvlddmkm+1498a70
MODULE_NAME: nvlddmkm
IMAGE_NAME:  nvlddmkm.sys
STACK_COMMAND:  .process /r /p 0xffffba0a3a6c2040; .thread 0xffffba0a607e3080 ; kb
FAILURE_BUCKET_ID:  0x116_IMAGE_nvlddmkm.sys
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {c89bfe8c-ed39-f658-ef27-f2898997fdbd}
Followup:     MachineOwner
0: kd> lmvm nvlddmkmBrowse full module liststart             end                 module name
fffff803`29910000 fffff803`2d380000   nvlddmkm T (no symbols)
    Loaded symbol image file: nvlddmkm.sys
    Image path: nvlddmkm.sys
    Image name: nvlddmkm.sys
    Browse all global symbols  functions  data  Symbol Reload    Timestamp:        Fri Apr 12 04:44:07 2024 (66184B97)
    CheckSum:         03958DF1
    ImageSize:        03A70000
    Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4
    Information from resource tables:I will put all the problem screenshots and dmp files in the attachment.
The dmp file url is
https://1drv.ms/u/c/a39a49f2cf648b69/ESkkr1sLImFBqo6DKRwozuYBt5SjbVs613s1aXGb2sZ-xg?e=xWFqQR
During this period, I also went to the repair shop for my laptop to replace the motherboard and reinstalled the system countless times. I also used DDU to reinstall many versions of the graphics card driver, but it didn't work.
My laptop is Lenovo Y9000P 4070
设备名称 DESKTOP-03QUNK0
处理器 13th Gen Intel(R) Core(TM) i9-13900HX 2.20 GHz
机带 RAM 32.0 GB (31.8 GB 可用)
设备 ID B49C4B0C-D7F2-41E6-8A3E-E8DEA70BF0AC
产品 ID 00326-10000-00000-AA630
系统类型 64 位操作系统, 基于 x64 的处理器
笔和触控 没有可用于此显示器的笔或触控输入
版本 Windows 11 Home Edition
版本号 24H2
安装日期 ‎2024/‎11/‎1 ‎Friday
操作系统版本 26100.1742
体验 Windows Feature Experience Pack 1000.26100.18.0
Hope to get help from the community.
tks!
DeancR_Intel
Hi LongSir,
Thank you for posting in the Community!
I understand that you have a laptop. Since this is an OEM (Brand) original equipment manufacturer device, please take into consideration that our support may be limited since we are not familiar with the technology, settings, customizations, custom drivers, and features that the OEM has designed and installed your system, nevertheless, I will do my best to assist you with your concern. I hope it's okay.
I suggest doing clean installation of the latest OEM drivers.
The link for the driver:
Lenovo Support | Drivers, Troubleshooting, Warranty, Repair | Lenovo Support US
  1. Perform a graphics driver clean installation with the Display Driver Uninstaller (DDU). For steps, see How to Use the Display Driver Uninstaller (DDU) to Uninstall an Intel® Graphics Driver.
  2. Update BIOS to the latest version.
  3. Disable hardware acceleration in all browsers. Contact the browser developer for steps.
  4. Perform a clean installation of the operating system.
  5. If the issue persists, contact system manufacturer.
Here's the link for your reference:
Blue Screen of Death (BSOD) dxgkrnl.sys, igdkmdn64.sys, 0x00000116 in...
Dean R.
DeancR_Intel
Hi LongSir,
Dean R.
LongSir
Sorry to bother you, my question is not solved
There is an Intel program that keeps reporting errors that cause my computer screen to freeze and then automatically restart.
Status: 0xC0000365
I just want to know why this keeps going wrong
Some other information
Card Name: NVIDIA GeForce RTX 4070 Laptop GPU
Thanks!
QuangThai
Try deleting all the keyboards, leaving only the English keyboard.
I encountered the same error and successfully solved it by the above method.
LongSir
Thank you very much, I'll try it
LongSir
hey,bro
I tried your method, but it didn't work.
thank you all the same!
QuangThai
I think you should reinstall Windows 11 23H2 version. There are reports of 24H2 update causing system errors, it is not completely stable.
LongSir
Actually, I upgraded from 23H2, just to guess whether this problem has been fixed in 24H2, but now it seems that it has not been fixed...HAHAHA!
DeancR_Intel
Hi LongSir,
Please update the Intel Innovation Platform Framework Processor Participant Driver using the following link: Intel Innovation Platform Framework Processor Participant Driver for Windows 10 (Version 22H2 or later) - Lenovo Laptops - Lenovo Support US
However, I'm not certain if this is the correct link for your specific system model. If you encounter any issues, please contact Lenovo for further assistance.
Additionally, please ensure that your BIOS is updated to the latest.
Dean R.
DeancR_Intel
Hi LongSir,
Dean R.
DeancR_Intel
Hi LongSir,
Dean R.
Yessi
I usually don't respond on any of this but i found the solution for me
I had the same Error but I have an AMD processor on a Asus MB
I was verifying in the Armory Crate app on the Tools section and found out that i had a diferent driver on my MB
That number was 6.10.xxxx but lastest driver says 6.05.xxxxx
this got me confused so i went to the MB driver download page and search for that driver, on that page says 6.05 so I download it from there
and that resolve the problem,
So Try to do the same on your specific MB
Hope this help someone out there
PRIME B550M-A AC
AMD Ryzen 5500
RTX 3060
LongSir
Hi,bro
When you replied to my post, I was at Lenovo's offline repair shop, so I didn't reply in time! The maintenance staff upgraded the BIOS of the independent graphics card and motherboard for me. I don't know if it has fixed the problem. If it still doesn't fix it, I will follow your method. Thank you very much!
By the way, my computer is a laptop.
Lenovo Legion Y900P 2023
RTX 4070 Laptop GPU
Intel I9 13900HX
Motherboard Name Lenovo LNVNB161216
Spencer9
Hey I have the exact same chip and gpu as you, and I am having the exact same issue. Just wondering if you ever fixed your issue and if you did what did you do?
