Intel® ARC™ Graphics
3428 Discussions
Fan curve is randomly disappearing and reappearing in Arc Control
TheWonderfulPie
At the Performance -> Performance tuning in the Arc Control software, the fan curve is only available sometimes for me. I noticed that most of the time when rebooting, it disappears, and forcing every Arc software to quit in Task Manager solves the issue most of the time. But sometimes, it will disappear for no visible reason. I also just noticed that when it appears, sometimes I'll have 3 points where I can change the curve, and sometimes I'll have 5 points where I can change it. I've already did a DDU
I've linked the Intel Scan
Jean_Intel
Hello TheWonderfulPie,
Thank you for posting on the Intel️® communities. We will be more than glad to help you.
It is crucial to mention that we are working to implement the Fan Control option in Arc Control, which should be enabled soon. We regret to inform you that this is still a work in progress and will require more effort from our end. As a result, we cannot provide an estimated time at this moment.
Jean O.
Jean_Intel
We hope you are doing fine.
Best regards.
Jean O.
