Intel® ARC™ Graphics
3331 Discussions
Fan curve suggestion for Intel Arc graphics and tips to improve the fan curve tips
addelucas123
New Contributor II
Good afternoon
I wanted to once again tell you that you give me tips for an optimal fan curve to improve the temperature. Then the suggestions I would like the next drivers' fan curve to work a little more, the curve at least approximately 1000 RPM, for better optimality and better temperature for both the system and demanding games, right now I have it set to 35% and I get 45 to 44 degrees, before it was 49 and 50 degrees, I wanted to send suggestions for you to improve the curve or tips for all users for greater optimality and better temperature, also consumption improve
addelucas123
New Contributor II
This is how 75 and 76 degrees are maintained with that fan speed of the Intel Arc graphics card, so I would like suggestions or tips for better optimization of both the system and the triple AAA game, so that the temperature is 75 and 76 degrees, Photo control, If I set the automatic fans as standard, 80 to 81 degrees, in this way by setting the appropriate settings or I don't know if they are adequate, we get 75 to 76 degrees, put a peak of 77 degrees, so the graph will last longer More or less I wanted to give suggestions so that you can improve the fan curve issue, both the system and demanding triple AAA games, Probe Red Dead Redemption 2 is a demanding game with vulkan and nothing 75 and 76 degrees, of course it doesn't go up any more, and if it goes up The top or peak will be 77 degrees, that does make noise, the fans start to work at 2848 RPM, noise is not noise, it is noticeable but it is not exaggerating and saying poof that the noise is loud etc, it is not making noise, but it can be, As I told you, suggestions or tips from driver engineers, advice for better optimal fan curve, both the system and a demanding triple AAA game, an example of RDR2, Let's see if you can and the issue of consumption improve a little more, I only ask for that nothing else.
Hugo_Intel
Hello addelucas123
We noticed this same topic is being discussed under your other thread with the title "Solved and temperature problem of the Intel Arc A770 graphics card" and also discussed under another internal case you opened with us, so in order to prevent duplicate efforts we will be closing this thread. Feel free to open a new topic in case you experience any other issues. Thank you for your understanding.
Hugo O.
