Intel® ARC™ Graphics
3427 Discussions
I can´t seem to get 3 monitors working at the same time
Xybles
I decided to plug in a 3rd monitor today and for some reason they´re all detected but only 2 work the other one goes to no signal and when i try to change the primary monitor another one goes no signal and the one that didn´t work comes back online when I look in the intel centrum it seems that one monitor then says that it is ´turned off´ in the system while it is turned on and has power. Does anyone know why this is happening? I got a intel uhd graphics 630 and it should be able to run 3 monitors at the same time and all the cables are plugged in nice and good
Alberto_R_Intel
Xybles, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
In order for us to provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
Is this a new computer?
Were you able to ever connect 3 monitors on this specific machine before without showing the issue that you are describing?
Did you make any recent hardware/software changes that might cause this problem?
Albert R.
Xybles
What is a ssu? Yes my computer is new (3 days old) and i've never had 3 moniyors connected before. I updated the graphics driver today to the newest version. The problem is accuring at a home environment.
Alex0072
It seems there might be a graphics setup issue. Make sure your graphics drivers are updated. Try changing the connections or using different ports on your computer. Also, check your display settings to confirm if the third monitor is recognized and enabled correctly.
Xybles
Yes I updated the graphics drivers their latest version today and yes windows does seem te detect but not enable it when I try to enable it with the intel software it doesn't do anything and I already tried switching ports didn't do anything
Alberto_R_Intel
Hello Xybles, Could you please provide the SSU report so we can further assist you with this matter? Check the link below for further description of the report:
Albert R.
Alberto_R_Intel
Hello Xybles, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello Xybles, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
