Intel® ARC™ Graphics
3365 Discussions
Improve Intel Arc performance Indiana Jones and the Great Circle PC
addelucas123
New Contributor II
Good morning, Once again, I want to take a step forward, Since the drivers are not yet mature or 100% It turns out that the game requires a lot of requirements, But you should also keep in mind that the minimum requirements ask for Intel Arc A580 that is minimum, But if I have the Intel Arc A770 I should play in recommended at least in very high or extreme quality at least 65 FPS in 2K 2560x1440 native resolution at 170Hz, Indiana Jones and the Great Circle tells me that my Intel Arc A770 16GB LE is to play native 2K in very high quality at 60 FPS it may reach 65 70 FPS, but Arc A770 16GB is to play 2K in high quality mode at 60 FPS native, with the Intel XeSS issue it can increase 70 75 FPS it works for me, But I would like to be able to play at full not at max extreme that asks for 10GB or 12GB of VRAM, If I have 16GB of Intel Arc A770 VRAM, everything should go to maximum native 2K according to their comments 60 FPS stable more or less 55-65 FPS with peak 70, But it goes to the middle 25 to 30 FPS and some areas 20 FPS 2K, I have gone from 1080p 35 FPS all to maximum, I need you to please improve the performance and come to an agreement.
I tell you that the game called Indiana Jones and the Great Circle is a demanding game, But support for that game tells me that my graphics card being Intel Arc A770 16GB LE should play 2560x1440p, that is, native 2K without upscaling at 60 FPS, Now I would like that apart from that you improve drivers or performance boost an extra 100% performance both 1920x1080p and 2560x1440p, Remember that Support tells me that my Intel Arc A770 graphics card is equivalent or equal in performance to an RTX 3080 Ti, As I know that you are continually working on performance, I also want the Intel Arc A770 to improve the performance of that game a 100% or 50% boost And that my graphics card is to play in high quality some ultra native things without upscaling 2K at 60 FPS it may reach 65 70 FPS, On the other hand Indiana Jones and the Great Circle I have not yet seen Intel XeSS rescaling technology, I also want us to take a look or take seriously that Intel XeSS 2nd Frame Generation receives, so that it reaches higher frames per second and less latency both the GPU and CPU, It is very important that you take this very seriously please.
I will pass screenshots of the Indiana Jones and the Great Circle requirements so that you can test the internal performance laboratory, but we return to the same topic of improving performance.
Intel Arc A770 Driver Version: 32.0.101.6332 Latest Drivers
addelucas123
New Contributor II
I'm telling you that I don't have a video of Indiana Jones and the Great Circle. I'm not recording it because it's unplayable and I need you to take this very seriously, please.
addelucas123
New Contributor II
Good morning, I want to congratulate you on the latest drivers 32.0. 101. 6449 / 32.0. 101. 101. 6256 Intel Arc A770, What a great change in performance and on top of that 2K, I'm playing it natively with everything to maximum without rescaling at 53 to 65 FPS bordering on 70 FPS, there is an 80 FPS area, I want us to continue improving the performance of Indiana Jones and the Great Circle, My graphics card should at least play ray tracing in medium quality 65 or 70 FPS and if I want to play in ray tracing on high as long as it goes to 45 to 50 FPS in native 2K resolution is fine for me, When Indiana Jones and the Great Circle receives Intel XeSS this is going to get interesting and Intel Arc A770 will compete with the RTX 4070, But it has left my mouth wide open, I'm playing everything at the maximum that the game gives without ray tracing, that is, the game comes with ray tracing but in the options I can activate it, but as I say I have it at maximum 1440p, that is, a native resolution of 2560 X 1440, it runs with everything at maximum 53 to 65 FPS with a peak reaching 70 FPS with everything to maximum, I can't imagine when you continue to improve performance even more etc etc that graphic card how it reaches more than 70 FPS 85 FPS or 90 FPS I tell you that I will be able to play up to ray tracing at high without complications as long as Intel XeSS is activated, but it has left me open-mouthed
But right now with the Indiana Jones and the Great Circle game configuration with the Intel Arc A770 at 1440p with all the settings to maximum which would be Supreme, that is, ultra goes Supreme, well I have it at Supreme which surely asks for 12GB VRAM and I have 16GB VRAM Intel Arc A770 it works natively, well native using rescaling that the game has without Intel XESS or AMD FSR 53 at 65 FPS reaching 70 FPS, right now I am surpassing it RTX 4060 Ti and RTX 4070, What a good job, Ole that's how it's done Intel, Big applause !!!!
To continue improving performance even more, because I want to activate ray tracing to see how far my graphics can go, etc., more improvements and also communicate it to the engineers
addelucas123
New Contributor II
Let's see the game Indiana Jones and the Great Circle has dynamic upscaling, I am using dynamic that uses 2560x1440 50%, if I remove dynamic 2560x1440 it uses 100% but the performance is 40 to 43 45 FPS, but I still like that we continue to improve as bigger
addelucas123
New Contributor II
Good morning, Let's see the problem is the performance, the game is playable, but I prefer more stability and better improve the performance of Indiana Jones and the Great Circle. As you can see, it is a very demanding game, it requires a lot of GPU, but I have to have a high GPU. performance and a little demanding a bit demanding Intel Arc A770 16GB, I have it on Supreme okay that would be the maximum that the game gives, okay it maintains good good FPS of playable performance, but I would like it because I am playing it native without upscaling eye and me It ranges from 32 or 31 depending on the area to 40 to 45 FPS, if it is playable, but of course I would like the performance to improve, because the graphics perfectly reach 70 FPS even with a peak between 80 and 85 FPS, and I am playing it native because I still There is no Intel 80 to 85 FPS, Let's see if you can improve a little more, as in the past we have improved Indiana Jones in supreme quality 1080p by 15%, 1440p we have improved performance by 25%, something like that, but I repeat my graphics are high performance and you are a little excited I don't know if I explained it to myself, but my graphics card has enough power to run that 1440p game that would be 2K above 60 FPS and it is also capable shoot 4K 45 FPS stable, having the 16GB of VRAM graphics, it has power and more than it can, what you have to continue improving and more things
1. Performance problem: forest or grass or water there drops from 30 to 45 FPS
2. Performance problem: Himalayas, which is snow, grass or water, there is a drop in performance, you must improve something
3. each zone or chapter drops performance, that's why I need you to improve performance
