Intel® ARC™ Graphics
3295 Discussions
Improve Mafia 3 performance a little more
addelucas123
Nouveau contributeur II
7 092 Visites
Good morning
I wanted to congratulate the community and Intel support and engineers. The performance of Mafia 3 has corrected the problem, but it can be improved a little more, because there are areas that need to be lowered from 57 to 115 FPS and some areas 150 FPS, so Which if you remember that my performance dropped a lot, you remember that I was facing 30 FPS, okay, now I get from 57 to 115 FPS, and some areas reaching 150 FPS, please one more push to improve the performance in drivers in DirectX 11 , I will try Days Gone, to see if it has improved or not, if it has not improved it must be reported, it will still be reported, why am I going to do a test etc. But the Mafia 3 well made but very well worked and hard, but it lacks improve a little more at least get there
between 85 to 95 FPS in the areas where the driver performance still needs to be further polished, instead of 57 FPS, it can exceed 85 or 95 FPS. If it is achieved with the Intel Arc A770 graphics, **bleep** for tat, you have surpassed the graphics RTX 3060 Ti and if the other area goes to more than 100 FPS, because there are areas that perfectly reach 150 FPS, it means that my Intel Arc A770 graphics card surpasses RTX 3060 Ti by a landslide by 10% and I bet that It can be on par with an RTX 3070 and I can say that in modern API DirectX 11 and 12, the Intel Arc A770 graphics card may outperform the RTX 3070 in some games. Well done Intel Well done
Therefore I am sending you a photo in the areas where I am still pending in improving the performance of the Mafia 3 game to get from 57 FPS to 85 to 95 FPS, and if it can be 150 FPS in all areas except the area where there are many loads What can I respect to see if it can be 100 FPS round, Please well done to the technical support and the Intel drivers engineers, for putting up with me etc, But you can beat the Intel Arc A770 to RTX 3060 Ti, because I tested with an RTX 3060, and I must say that you have surpassed it, Mafia 3 with an RTX 3060 in the affected area achieves 53 to 70 FPS, and my Intel Arc A770 57 to 85 FPS, but I repeat if it can be achieved from 85 to 95 FPS and if it can being round at 100 FPS would be a big hit and I also bet that it surpasses the RTX 3060 Ti, a hug and well done
0 Compliments
18 Réponses
addelucas123
7 089 Visites
Well, Days Gone has not improved the performance, I get 39 to 55 FPS, some areas 60 FPS. It is very far from surpassing an RTX 3060 and RTX 3060 Ti with my Intel Arc A770 graphics card. The same is reported
0 Compliments
Hugo_Intel
Employé
7 020 Visites
Hello addelucas123
Thank you for posting on the Intel® ARC™ Graphics Communities.
Is the area outlined in the screenshot the only one affected? Or is this reproducible in other areas?
We would need a video to check how the GPU is behaving on your system as well as a screenshot of the in-game graphics settings in case we need to test or you can show them in the video as well.
In addition, Have you tested the game with driver 4952? Or what driver was this tested on?
Hugo O.
0 Compliments
addelucas123
7 014 Visites
Indeed I use the latest version of the 4952 drivers, it is the only area affected as I sent you the image, I will send you the video so you can see
0 Compliments
addelucas123
7 009 Visites
Here is Mafia 3, when I upload the video, I will give you the link, so you can see that the performance is low and see that I am not lying to you.
0 Compliments
addelucas123
7 007 Visites
Here is the video of Mafia 3 so you can see that I am not deceiving you, and I have everything updated with clean deinstallation, etc.
https://youtu.be/AAhnsUwD6T0?si=TkwCYV1dtHau5fSG
0 Compliments
Hugo_Intel
Employé
6 928 Visites
Hello addelucas123
We will take a further look at this problem and will let you know since the issue only happens in one specific area this might be related to the game optimization itself rather than the Arc Graphics drivers so we cannot commit to a specific outcome, however, allow us to check and we will let you know as soon as there is an update for you.
Hugo O.
0 Compliments
Hugo_Intel
Employé
6 862 Visites
Hello addelucas123
We just want to let you know that we are still testing this game to check if there are any type of performance issues. Please bear with us as we finish testing the game, we will give an update once we have more information.
Hugo O.
0 Compliments
Hugo_Intel
Employé
6 794 Visites
Hello addelucas123
We finish the test on this game and we will continue analyzing the results. Once we have more information and our conclusion we will let you know and post back.
Hugo O.
0 Compliments
Hugo_Intel
Employé
6 746 Visites
Hello addelucas123
We appreciate your patience. We want to let you know that we tested this game with our driver 31.0.101.4972 and noticed a performance issue in the area called "Centro" as you pointed out, however, with our new driver that was recently released version 31.0.101.5074 we no longer see ay problem and the game performs around 80-90 fps most of the time, check this video for reference. In this case, we recommend that you update to our latest driver and test the game at high settings and 1080p resolution, also make sure that no third-party apps are running in the background when testing, and let us know if you see an improvement as well. We continue to work on more updates for DX11 titles so you can expect further improvements in future drivers.
Hugo O.
0 Compliments
addelucas123
6 734 Visites
Hi Hugo, For me it is 58 to 95 FPS, it has improved compared to 50, Now it is 58 to 95 FPS some zones 105, But that performance is not working for me, Something has to be done, I have everything updated to the latest version of drivers etc., Something has to be done, keep improving, tell the engineers who are half fixed in quotes to continue improving and when it improves 100% I will say well look at how it has improved, but now I need you to continue
0 Compliments
Hugo_Intel
Employé
6 724 Visites
Hello addelucas123
Based on the video we just shared in our previous post the fps did not go under 80 fps at any moment in the area that you originally reported which is "Centro". If you are still experiencing issues we recommend you use DDU and update to our latest driver 31.0.101.5122, make sure to get the game in high settings at 1080p.
If the performance problem still happens in the "Centro" area, please share a short video so we can compare with our tests.
Hugo O.
0 Compliments
addelucas123
6 710 Visites
I just installed the latest version 31.0.101.5122, but 31.0.101.5081 is installed, I did the steps you told me and on top of that the performance is lower 48 to 95 FPS some areas 115 FPS all on high
0 Compliments
Hugo_Intel
Employé
6 682 Visites
Hello addelucas123
I see you are still experiencing performance problems on this game, Could you please share a new video showing the performance of the game's behavior so we can compare this with our tests?
Hugo O.
0 Compliments
addelucas123
6 667 Visites
Here it is, the video lasts two minutes and the game is Spanish, try as best you can, I'll send you a photo so you can see that I have resizable bar activated and the latest version but the problem persists, etc.
https://www.youtube.com/watch?v=o2jXhKa_QRk
0 Compliments
Hugo_Intel
Employé
6 660 Visites
Hello addelucas123
Thank you for sharing the feedback. I will share the information with our team and will get back to you once I have an update on this.
Hugo O.
0 Compliments
addelucas123
6 450 Visites
Here you have information about the graph as you always ask for but the low performance still persists.
0 Compliments
Hugo_Intel
Employé
6 433 Visites
Hello addelucas123
We want to let you know that we have tested the game with our latest internal driver and this issue can no longer be seen, check the following video so you can see the test: https://www.youtube.com/watch?v=xLEkRLth8as. As mentioned this test is in our internal driver. It is expected to be released within the next 2-3 public driver releases, so our advice is to keep your driver updated and wait for future improvements to be added to this game.
Hugo O.
0 Compliments
Hugo_Intel
Employé
6 337 Visites
Hello addelucas123
As mentioned in our previous post, please look forward to the next driver updates that will continue to improve the performance of Mafia 3. Since there are no further questions we will now close this thread.
Hugo O.
0 Compliments
Répondre
