Intel® ARC™ Graphics
3293 Discussions
Incredibly Low Performance on FlightGear 2020.4
FurryMLG
fgfs-20240607235248.pngfgfs-20240607235500.pngRunning on Both Even the Highest and Lowest settings, FGFS only averages 3-4 fps.
The menu says your GPU may not support complex graphics.
Labels (2)
Mike_Intel
Hello FurryMLG,
For us to further check this, please help generate the SSU logs of your system.
Kindly download the utility here:
https://www.intel.com/content/www/us/en/download/18377/intel-system-support-utility-for-windows.html
Michael L.
FurryMLG
Here are the tags
Mike_Intel
Hello FurryMLG,
Thank you for the update.
Upon initial checking of the SSU, I found that the driver of your Graphics is already updated. However, let me also check for the following details.
  1. You have 2 Graphics controller, have you checked which on is enabled inside the BIOS?
  2. Is the BIOS of your motherboard updated?
  3. Did you enable the Resizable Bar? If not yet, please follow the link below on how to enable it:
https://www.intel.com/content/www/us/en/support/articles/000090831/graphics.html
Michael L.
FurryMLG
ReBar is enabled.
And my Arc is plugged into the monitor, and in FG, shows the Arc Selected.
Mike_Intel
Hello FurryMLG,
By the way, can you also share the specification of your power supply? Can you provide the wattage of it?
Michael L.
FurryMLG
Mike_Intel
Hello FurryMLG,
We will do further research on this matter and post the response on this thread once it is available.
Have a fantastic day, and thank you very much for your patience and understanding!
Michael L.
Mike_Intel
Hello FurryMLG,
We would like to provide these steps so kindly try to follow it and check if there will be improvements:
1. Proceed with a DDU and then reinstall the latest graphics driver (version 31.0.101.5534). This will help us ensure that the driver is updated correctly.
2. Adjust the settings to designate the Arc graphics card as the default for the game. You may refer to our detailed guide titled How To Set the Default GPU for Applications and Games.
3. If still the same, please help provide the download link for the game? This will enable us to accurately replicate the issue and provide more targeted support.
Michael L.
Mike_Intel
Hello FurryMLG,
Michael L.
FurryMLG
I have been able to update, low performance still persists
Mike_Intel
Hello FurryMLG,
Please help share the download link for the game, we will try to install and replicate the issue in our lab.
Michael L.
Mike_Intel
Hello FurryMLG,
Thank you for sharing the link.
We will to simulate this issue using this game and post the response on this thread once it is available.
Michael L.
WStefan
Hello @ALL,
sorry for jumping into this thread, if it is inappropraite, please let me know. I am facing exactly the same issues as TO.
Have you investigted into this and can share some details?
Thank you and
Best regards
Stefan
Espionage724-0x1
I'm experiencing this too (troubleshooting and etc on FlightGear's forum): https://forum.flightgear.org/viewtopic.php?f=37&t=42656
On Windows, FlightGear's performance is awful (15 FPS). On Linux and FreeBSD on the same computer, FlightGear's FPS is great (50-75 FPS). Drivers 2127 and 2130 Windows 10 21H2 and 11 24H2 are all the same.
I have Intel UHD 630 (not Arc), but believe there to be something non-optimal in-general with the OpenGL driver on Windows.
