I upgraded to an Intel Arc A750 GPU about 2 months ago. It has worked very well so far. Since Friday (12/24/20) there have been some crashing issues. This happened for the first time when I was playing Forza H. 4 for about 2 hours when the game just closed. After approx. I couldn't play it for more than 20 minutes, because everytime crashed. I tried another game (Assetto Corsa) and it also froze after 20 minutes. And according to the log, it's probably GPU overload. I tried a clean reinstall of the GPU driver but it didn't work, so I reinstalled full Windows (11 PRO) and then reinstalled the driver (version: gfx_win_101.6325_101.6253) but that didn't fix the problem either. I was able to solve the problem by setting the fps limit to 60 FPS, because of this the GPU only runs at around 50-60% and thus does not freeze, but I would like to use it at higher performance because I have a 100Hz display. The GPU never goes above 65°C and is properly powered.
Event viewer says:
Faulting application name: IntelGraphicsSoftware.exe, version: 24.48.47.5, time stamp: 0x66e80000
Faulting module name: Microsoft.UI.Xaml.dll, verzió: 3.1.6.0, időbélyeg: 0xe09b717f
Exception code: 0xc000027b
Fault offset: 0x0000000000009125
Faulting process id: 0x1AA0
Faulting application start time: 0x1DB55E424110877
Faulting application path: C:\Program Files\Intel\Intel Graphics Software\IntelGraphicsSoftware.exe
Faulting module path: C:\Program Files\Intel\Intel Graphics Software\Microsoft.UI.Xaml.dll
Report Id: f0df3019-2f7d-44b9-8a88-e0c723e808c8
Faulting package full name:
Faulting package-relative application ID:
and,
Faulting application name: IntelGraphicsSoftware.Service.exe, version: 24.48.47.5, time stamp: 0x66e80000
Faulting module name: KERNELBASE.dll, verzió: 10.0.26100.1882, időbélyeg: 0xdebc683b
Exception code: 0xe0434352
Fault offset: 0x00000000000c83ea
Faulting process id: 0xE84
Faulting application start time: 0x1DB55E3B807EC04
Faulting application path: C:\Program Files\Intel\Intel Graphics Software\IntelGraphicsSoftware.Service.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: fa6b2178-b37a-4870-922e-406bbae7bfcf
Hello RcLevi,
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
1) What is the graphics driver you are using?
- Current graphics driver installed.
 - Driver version tried.
2) Platform where the games (Forza H and Assetto Corsa) are launched and where to obtain it (Steam, Epic, etc. in case we need issue replication).
3) Provide us with the Intel SSU report from your system. When the download is complete, launch SSU.exe.
- Scan: Check the box Everything.
 - Click Scan.
 - Review: When finished scanning, click Next.
 - Click Save (.txt)
- NOTE: If you do not wish to submit the SSU report then at least provide us with the following information about your system:
- Processor make and model.
 - Motherboard make and model.
 - Amount of memory (RAM).
 - Operating System version/build number.
 - Power Supply make and model.
4) Tell us the steps to reproduce the issue.
5) Make and model of your Display/TV/Monitor.
6) Describe the FPS performance issue as best as you can.
- Per example: FPS drop when entering ‘x’ or ‘y’ section.
I will wait for your reply.
JeanetteC.
I have the same issue with last guy, but not the same game :delta force
FYI as below:
| + | System |
| - | EventData |
| AppName | IntelGraphicsSoftware.Service.exe |
| AppVersion | 24.50.1001.1 |
| AppTimeStamp | 66e80000 |
| ModuleName | KERNELBASE.dll |
| ModuleVersion | 10.0.26100.2454 |
| ModuleTimeStamp | 398a1cce |
| ExceptionCode | e0434352 |
| FaultingOffset | 00000000000c837a |
| ProcessId | 0x115c |
| ProcessCreationTime | 0x1db5dadbea33dd9 |
| AppPath | C:\Program Files\Intel\Intel Graphics Software\IntelGraphicsSoftware.Service.exe |
| ModulePath | C:\Windows\System32\KERNELBASE.dll |
| IntegratorReportId | 001c9c82-81b1-43c0-bcd5-7e13c3280f8f |
| PackageFullName |
| PackageRelativeAppId |
| + | System |
| - | EventData |
| AppName | IntelGraphicsSoftware.exe |
| ModuleName | Microsoft.UI.Xaml.dll |
| ModuleVersion | 3.1.6.0 |
| ModuleTimeStamp | e09b717f |
| ExceptionCode | c000027b |
| FaultingOffset | 0000000000009125 |
| ProcessId | 0x18a8 |
| ProcessCreationTime | 0x1db5dd2df5ec572 |
| AppPath | C:\Program Files\Intel\Intel Graphics Software\IntelGraphicsSoftware.exe |
| ModulePath | C:\Program Files\Intel\Intel Graphics Software\Microsoft.UI.Xaml.dll |
| IntegratorReportId | 301929f1-4f55-4bf7-aaf9-a2616424bb8b |
| PackageFullName |
FYI as below:
- Current graphics driver installed:-6256
 - Driver version tried:-6253
2) Platform where the games Delta Force are launched and where to obtain it :
-Steam and wegame all have same issue in same game
-as attach.
4) Tell us the steps to reproduce the issue:
-when you start in game ,the screen just black,game crashing and PC restart
-60HZ monitor
- Per example: FPS drop when entering ‘x’ or ‘y’ section. -game not start ,no FPS item show.
Hello RcLevi,
Good day!
I'm following up to check whether you have had the chance to review our prior correspondence. If you have, kindly acknowledge receipt and let me know if you need time to share the details I asked for. Please let me know about this information so we can identify the next steps that need to be taken to resolve this issue.
JeanetteC.
Hello zhangweiliang,
I understand that you are facing the same problem with a different game. However, I kindly request that you create a new thread for your case. This will allow us to focus on your specific problem and provide you with better assistance.
Sincerely,
JeanetteC.
Hello RcLevi,
Since I have not heard back from you, I will close this thread. Should you need assistance in the future, please submit a new question as this thread will no longer be monitored.
Sincerely,
JeanetteC.
