- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
In some game scenarios it can reach 99% but generally it's between 95-80 or even less.
From what I have seen, it's not a CPU bottleneck because you can get more and stable GPU usage using the same processor with more powerful GPU.
system specs:
CPU: Ryzen 5 7600.
Motherboard: Asrock B650 Steel Legend.
RAM: 32 GB DDR5-6000Mt/s.
GPU: Asrock Challenger Intel Arc A750.
Drivers: 32.0.101.5989
Game video settings and some screenshots in the images.
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Megamagner,
GPU usage or utilization is dependent in how much rendering is needed on the game. There will be some certain cutscenes or events in the game that it will low or high the usage of GPU. To further investigate this see the following question below:
- Are you having issues when the utilization of GPU is down? Like freezing, crashing, hanging?
- What driver version are you using?
- Does this also happen on other games? If yes, can you share the name of those game?
I am looking forward hearing back from you
Dhanniel M.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Dhanniel,
Thanks for the support!
Let me answer your questions,
1. Not freezing, crashing or hanging but FPS drop too, 38-45 while GPU usage is at 80-95.
2. I use the 32.0.101.5989 driver version.
3. It only happens in this one, in other games like Warframe the GPU usage is at 99%, except for menus and cinematics.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Dhanniel,
Thanks fot the support!
1. Won't freeze, crash or hang, but fps drops with GPU usage. If GPU usage is at 99% and drops to 80 or 70%, FPS drops from 65-55 to 45-38 without freezing or stuttering. Usually drop in open areas full of enemies or with many particle effects.
2. I use the 32.0.101.5989 drivers version.
3. It just happens in this one, in other games like Warframe it stays at 99% while play, except for menu and cinematics.
I will be waiting for any other requirements.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Megamagner,
Dhanniel M.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Megamagner,
I apologize for on my previous response. There are just some clarifications that I would like to ask on this, please see questions below:
- When you say your FPS is dropping, can you tell me what is your expected FPS should be at certain GPU utilization?
- Also, do you have a reference where you are comparing the FPS?
- What is the best FPS you are achieving?
- Can you share your game setting to us?
- Also, can you please utilize the CapFrameX, and export the data on JSON file and share it to this thread. You can follow these instructions About CapFrameX
Dhanniel M.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Megamagner,
I hope you had the opportunity to check the questions I posted. Let me know if at your earliest convenience so we can determine the next course of action to resolve this matter.
Dhanniel M.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi Megamagner,
Since I haven't heard back from you, I will be closing this thread. Though if you have other inquiries or further assistance, please submit a new post as this thread will no longer be monitored.
Dhanniel M.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
