Intel® ARC™ Graphics
3475 Discussions
LMU shadow strobing with ARC
Saabjock
The issue of flickering/strobing shadows and the inability to run Le Mans Ultimate with rear-view mirrors or in-game trackside videos displaying, still needs to be addressed.
I've searched the site and it has been reported numerous times...over several months.
I have tried multiple Intel drivers...all the way to the current 32.0.101.7029.
They've all exhibited the same behavior, i.e ....flickering or flashing on surfaces, when attempting to cast shadows.
It is clearly evident in the attached video on the pitwall adjacent to the pit box.
It is also there on the floor when exiting the pit to go on track.
It can also be seen where any overhead object tries to cast a shadow on any object below.
See the attached video....
Intel ARC_2025 09 04 06 16 37
Mike_Intel
Hello Saabjock,
  1. What is the model of your Graphics controller?
  2. What is the model of your processor?
  3. What is the brand and model of your system?
  4. Was it working fine before?
  5. If yes, what was the last change made before the issue started?
  6. How did you update the driver?
Michael L.
Saabjock
Please see the attached Intel SSU.
The data in that report was captured using the Intel 32.0.101.7028 driver.
I have since switched to the 32.0.101.7029 driver but I have gone through approximately six drivers previously.
It exhibits the exact strobing, even with that (latest) driver.
My card is the A770LE.
There is no overclocking on anything in the system....all drivers and motherboard BIOS are updated to the latest.
Mike_Intel
Hello Saabjock,
Thank you for the update.
Can you try re-installing the latest Graphics driver using DDU method and update me if you are still having the same issue.
Please refer to the link below for the steps and the download link of the latest driver:
How to Use the Display Driver Uninstaller (DDU) to Uninstall a...
Intel® Arc™ & Iris® Xe Graphics - Windows*
Michael L.
Saabjock
Every driver...including the current one were installed by using DDU in safe mode to remove the previous one.
A clean install is always selected.
The issue is the same for the previous five Intel drivers.
In addition, LMU will crash if any rearview mirrors or any ingame video screens are active.
Anna180
Hi @Saabjock,
This shadow strobing/flickering in Le Mans Ultimate with Intel ARC GPUs is a known issue reported by multiple users. Since you’ve tried all drivers up to 32.0.101.7029, it seems driver-side fixes haven’t fully resolved it yet.
A few steps you can try as workarounds:
  1. Lower shadow quality or disable certain shadow effects in-game.
  2. Toggle hardware-accelerated rendering or ray tracing options if available.
  3. Ensure game and GPU drivers are running the latest hotfix patches.
  4. Report your captured video and logs to Intel ARC Support to help prioritize a fix.
Until Intel releases a targeted driver update, partial workarounds in the graphics settings are usually the most reliable approach.
Saabjock
I guess I...we LMU users, will all need to wait for a driver fix because everything you have proposed, I have already tried.
The problem extends to not being able to turn on in-game videos jumbotrons or rearview mirrors on actual cars.
That information ought to be enough to get the driver team pointed in the right direction.
This issue is as old as LMU itself and has been reported for months...not days or weeks.
Thanks for the response.
Mike_Intel
Hello Saabjock,
For me to have this further investigated, please help provide the following details.
  1. What is your game launcher?
  2. Please share a screenshot of the game Graphics settings.
Michael L.
Saabjock
I have tried both STEAM and SimHub for launching....no difference.
Here is what it looks like using the external playback camera.
Notice the strobing on every surface a shadow should be cast on.
https://www.youtube.com/watch?v=-p7GX4VTyZE
20250917_000128 (FILEminimizer).jpg20250917_000149 (FILEminimizer).jpg20250917_000216 (FILEminimizer).jpg
Mike_Intel
Hello Saabjock,
I will do further research on this matter and post the response on this thread once it is available.
Michael L.
Mike_Intel
Hello Saabjock,
I just want to update you that I tried to replicate this issue in our lab using the same configuration however, I wasn't able to replicate the issue.
Because of this, let me recommend the following:
Michael L.
Saabjock
Hello Michael....
This is a known issue for Intel users only, in the LMU forum.
As an Intel employee, I highly doubt you would be testing with an AMD CPU. Please respond, stating if you did. Thanks.
As to my configuration.... I already had the latest ASRock X570S PG Riptide BIOS before submitting the issue here.
That version number is P5.67. I am also using the latest Intel driver but have had the issue with every Intel driver used.
All chipset drivers...all firmware for all items and all drivers are the most recent for all hardware.
Rebar has always been on since the day in December 2022 when the card was purchased and installed.
Mike_Intel
Hello Saabjock,
Let me further investigate this issue and update this thread as soon as I have an update.
Michael L.
Shaodichan
I can't imagine how you ignore user needs, neither AMD nor Intel CPUs can solve this problem. Both B-series and A-series graphics cards have their own issues in this game, and 397 has clearly stated that they have been resolved. The rest is your Intel driver problem. I can't imagine how garbage you are
Saabjock
Hello Michael, per the Intel SSU file submitted earlier in this trouble report....please be aware that I am using an AMD R7-5800X3D CPU.
I will reach out to the many affected Intel users in the Studio 397 LMU forum to see how many are using x3D CPUs.
I do know the issue is rather extensive on Intel hardware.
Mike_Intel
Hello Saabjock,
Thank you for patiently waiting for my update.
Please check the attached file for the details of my simulation and yes, I use an AMD processor during simulation.
Since the issue is not persisting in our end specially using the new graphics driver 32.0.101.8132, please try to contact the game developer Contact us | Le Mans Ultimate Community. for further assistance.
Michael L.
Saabjock
Hello Michael....
As previously stated, I am using an AMD X3D chip....which you clearly are not in the 5600G.
The other thing I see in your specification listing, is a vey low GPU utilization at 1%.
If you have captured that information simultaneous to the game running, then you are probably utilizing the AMD onboard graphics.
The issue is not solely a Studio397 issue because all Nvidia and AMD user of the title are running correctly with relation to the shadows. They're not experiencing the strobing I and other AMD x3d users are reporting.
If you tell me you do not know what the issue is, I can accept that.
Clearly there is something wrong with how the ARC driver is handling shadows in the title.
As an aside....I have now done another 'clean' removal of the previous 7029 driver and installed the newly released 8132.
The issue remains the same.
wen57213
Did you test the main race stage in LMU's online competition mode instead of the practice and qualifying stages, and did you not turn on the rearview mirror function during the test.
Here are the problems I encountered in the game.
Online competition mode
1. When loading online games, there is a low probability that the game will crash (the rearview mirror can already be activated).
2. Click on custom vehicle tuning in room P, and the screen will freeze 100%.
3. During the process of driving a racing car, the game screen may freeze, but through the FFB and sound of the game, I can feel that the vehicle is still running normally (the screen freezes at different times, with a 100% probability of occurrence).
There is no problem with single player mode, the above situation only occurs in online competition mode.
LMU 1.1
CPU AMD Ryzen 5 7600
RAM 32gGB
GPU intel ARC A770 16g driver version 32.0.101.7029
windows11 26100.4946
wen57213
After loading the track of Le Mans Ultimate's IMOLA, driving the race car out of the game will immediately crash
wen57213
When Le Mans Ultimate's IMOLA loads the track and drives the car out of the P room, the game will immediately crash
Saabjock
It seems the solution for now, is to turn off shadows and shadow blur.
Unlike many other sims, the cars will not look as if they're floating and will retail some ground effect shadowing underneath.
It looks way better...no more flickering trees or weird track shadows.
