Hello i have a problem in some older games like Assassin's Creed Syndicate or Portal i have strange low fps in AC its like 30 on high 1080p and Portal like 60 on max in 1080p i try all options and settings and on vulcan and dx11 but no fps up
Hello jabba2,
Thank you for reaching out to us! I understand that you are encountering Low FPS in your Assassin's Creed Syndicate with your Intel Arc B570. I understand that this is disruptive in your gameplay with our Graphics Card, rest assured, I'm here to help you address the issue being encountered.
To further investigate, please answer the following questions:
- May I know what game platform are you playing the game on?
- Is Resizable Bar currently enabled in your Motherboard's BIOS?
- Is the low FPS encountered on specific areas of the game or is this consistent all through out the gameplay/
- What is your current game settings? Kindly take a screenshot
- What is the Manufacturer of your Intel Arc B570? (Sparkle, Gunnir etc)
To assist us in analyzing the details of your system and addressing the issue effectively, we kindly ask you to generate a System Support Utility (SSU) report. This report will provide us with comprehensive information about your system's configuration, helping us identify any potential incompatibilities or issues.
To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*.
I look forward to your response!
Robbie R.
waiting for response
Jabba
Hello jabba2,
Thank you for patiently waiting and for providing the necessary information. I would like to clarify the following:
- May I know what game platform are you playing the game on? (Steam, EpicGames, etc)
- Is the low FPS encountered on specific areas of the game or is this consistent all through out the gameplay?
Robbie R.
i play on steam.
Resizable Bar is on on bios.
Low fps all the gameplay time
Hello jabba2,
Thank you for providing all the necessary information. I will now further investigate the issue being encountered on the above-mentioned game. I will get back to you once an appropriate resolution is available.
Robbie R.
Hello jabba2,
To further investigate the issue, please provide the following information:
I would like to confirm if you have performed a clean installation using DDU. If not, it is recommended to use DDU and install the latest graphics driver version, 32.0.101.6734
I would also like to obtain a CapFrameX to thoroughly analyze the FPS performance. Kindly ensure that the game would run for a minimum of 2 minutes.
Robbie R.
Hello jabba2,
I wanted to check in and see if you had a chance to go through the questions I shared earlier. Whenever it’s convenient for you, just let me know; I'm happy to continue assisting you.
Robbie R.
Hello jabba2,
Archie D.
