Intel® ARC™ Graphics
3385 Discussions
Not outputting display on initial boot or waking from sleep
thegrantpa
I am having an issue where I get no display output when starting my PC in the morning or when waking from sleep. When the issue occurs, my mobo displays a "VGA" error light indicating "the graphics card or the CPU with integrated graphics is not detected or failed". After getting this error light, I hold the power button to force shut down, wait a few seconds, then press the power button and the PC boots normally with display output.
I've removed the Arc card, booted from iGPU, removed all Intel Arc drivers and software, restarted to be sure it is all removed, then reinstalled Arc card and ensured the driver below is installed. However, the problem persists after this.
Any assistance is appreciated.
GPU: ARC A770 16GB
Driver: 31.0.101.3490
CPU: i5 11600K
Mobo: MSI MAG B560M BAZOOKA w/ BIOS 7D18vA7
RAM: 32 GB G.SKILL 3600 MHz
Boot: 500GB Samsung 980 NVME M.2
OS: Windows 22H2 22621.819
SomeFellowNumber3
Are there any settings in your bios that default graphics display to a specified pcie slot?
thegrantpa
I don't have any settings like this. Mobo also only has one PCIE x16 slot.
SomeFellowNumber3
Okay. Probably not that then.
Another complete guess: I see a Nvidia audio driver in your logs. Try uninstalling that and any other Nvidia graphics driver package stuff (unless you need it and you've got an external card configured or something crazy.)
On second thought, that error message seems to be coming from your motherboard. If that is true this issue is independent on windows drivers. I think the issue lies with either the graphics card, your motherboard or your CPU. Your motherboard is updated to the latest bios, and if it's in good condition it probably is not that.
LynxRufus
there should be..
in your case, since it's MSI, in your BIOS most likely in :
settings\advanced\Integrated Peripherals\VGA Detection
and/or or check
settings\advanced\Integrated Graphics Configuration\Initiate Graphic Adapter => set to [PEG]
settings\advanced\Integrated Graphics Configuration\IGD Multi-Monitor => [disabled]
also, are the settings  for ErP  &  Bios CSM disabled or  enabled ?
thegrantpa
Motherboard is 11 months old, running the latest BIOS. I have swapped cases and reseated every component a few times, but I'd say it's in good condition.
Carlos_L_Intel
Hello @thegrantpa
Thank you for posting on the Intel® communities and for the detailed information. I'm sorry for the inconvenience this might have caused you.
In both cases, I noticed that based on the information you provided you have an out-of-date driver, can you please update to version .3802: https://www.intel.com/content/www/us/en/download/726609/intel-arc-graphics-windows-dch-driver.html
Let us know how it goes after the update.
Carlos L.
thegrantpa
Thanks for the information Carlos. I did update earlier this week. I’ll update you if it still occurs.
Carlos_L_Intel
Hello @thegrantpa
My pleasure, please let us know of any updates. Thanks for your time.
Carlos L.
Carlos_L_Intel
Hello @thegrantpa
Carlos L.
Carlos_L_Intel
Hello @thegrantpa
Carlos L.
QuintinGreyling
I have exactly the same issue as you've described. This is happening with a new PC that I've built two days ago and the only component that was reused was my CPU which is a Ryzen 7 5700X. If I put my old RTX 3060 into the PC, I don't have this issue. It also only happens on a "cold boot" after the PC has been off for an hour or two. Immediately shutting down and starting up doesn't give this issue.
Can you please advise whether it was resolved and what you did to resolve it. It's a pity that the first time that I deviated from the "mainstream" GPUs, I have issues like this.
