- 新着としてマーク
 - ブックマーク
 - 購読
 - ミュート
 - RSS フィードを購読する
 - ハイライト
 - 印刷
 - 不適切なコンテンツを報告
Hi Guys,
I noticed that with updated latest drivers 31.0.101.4644, when open the Apple Music or Apple TV app on my windows 11 PC I get a black screen temporally for a few seconds and then go back to normal.
I have my intel arc a770 card plugged in via HDMI.
Specs:
Processor AMD Ryzen 7 7800X3D 8-Core Processor 4.20 GHz
Installed RAM 32.0 GB (31.7 GB usable)
OS: Windows 11 Pro
GPU:  Intel Arc A770
Let me know if you need any more details.
Thanks for your time
コピーされたリンク
- 新着としてマーク
 - ブックマーク
 - 購読
 - ミュート
 - RSS フィードを購読する
 - ハイライト
 - 印刷
 - 不適切なコンテンツを報告
Hello Yuenight
Thank you for posting on the Intel® ARC™ Graphics Communities. I see you are experiencing a black screen for a couple of seconds before the Apple Music software opens up.
I understand that the issue started with the latest driver 31.0.101.4644, if you roll back to the previous driver 31.0.101.4577 is the issue not happening? In order to rule out possible driver or software issues I would advise that you completely uninstall the Apple Music software and reinstall it on your system. As for the driver use Display Driver uninstaller to uninstall the previous driver version and then reinstall version 31.0.101.4644.
If the issue is still happening we would appreciate it if you could share a short video showing the issue and in case the problem is not happening when rolling back to version 31.0.101.4577 a short video showing the software working as it should so we can have a better understanding in case this needs to be tested.
Hugo O.
- 新着としてマーク
 - ブックマーク
 - 購読
 - ミュート
 - RSS フィードを購読する
 - ハイライト
 - 印刷
 - 不適切なコンテンツを報告
Hello Yuenight
I wanted to check if you had the chance to reinstall the driver as advised in our previous post, if so, please let us know if the issue is still present. In case the issues still exist share with us whether the issue is not happening in the previous driver and is possible a video showing the issue.
Hugo O.
- 新着としてマーク
 - ブックマーク
 - 購読
 - ミュート
 - RSS フィードを購読する
 - ハイライト
 - 印刷
 - 不適切なコンテンツを報告
Hi Hugo,
I have given you instructions a try.
1) I used the DDU in safe mode to uninstall the drivers.
2) When it restarted, installed 31.0.101.4644 and restarted the PC.
3) Open Apple music, and the issue happen the screen goes black for moment and then come back.
4) Upgraded to 31.0.101.4669 and then restated the PC.
5)Opened Apple music again same issue happen the screen goes black for moment and then come back.
Noted) That after the 1st opening of Apple Music this issues does not happen again, so 2 second time its fine. So no more black screen until I switch off my pc and boot it up again.
- 新着としてマーク
 - ブックマーク
 - 購読
 - ミュート
 - RSS フィードを購読する
 - ハイライト
 - 印刷
 - 不適切なコンテンツを報告
Hello Yuenight
Thank you for sharing the information and videos, we now have a better understanding of the issue. Just to confirm, Did you also reinstall the software on your system as well to discard possible app issues?
From your original post I see the issue started with driver 4644, but now that you also tested the 4577 version the issue is still happening, so was driver 4577 working fine before? Also, to discard possible physical issues, Could you please let us know the type of connections that you are using? , Have you tried different cables or types of connections HDMI and DP?
Hugo O.
- 新着としてマーク
 - ブックマーク
 - 購読
 - ミュート
 - RSS フィードを購読する
 - ハイライト
 - 印刷
 - 不適切なコンテンツを報告
Hi Hugo,
I just done an uninstall of the app with the latest drivers, (31.0.101.4699) black screen while using HDMI. Then I took you advice I switched the cable to Display Port now and the black screen is not happing.
I try a different HDMI cable once I order a new one and see if the issue still happens.
Thanks for your time.
- 新着としてマーク
 - ブックマーク
 - 購読
 - ミュート
 - RSS フィードを購読する
 - ハイライト
 - 印刷
 - 不適切なコンテンツを報告
Hello Yuenight
I see the issue is not happening on DP and that you ordered a new HDMI cable, in this case, we will continue to monitor the thread so you have the time to do the proper testing.
Hugo O.
- 新着としてマーク
 - ブックマーク
 - 購読
 - ミュート
 - RSS フィードを購読する
 - ハイライト
 - 印刷
 - 不適切なコンテンツを報告
Hello Yuenight
I wanted to check if you had the chance to test a new HDMI cable on your system and if the same flickering issue still happens when opening Apple Music. Please let us know.
Hugo O.
- 新着としてマーク
 - ブックマーク
 - 購読
 - ミュート
 - RSS フィードを購読する
 - ハイライト
 - 印刷
 - 不適切なコンテンツを報告
Hello Yuenight
We hope that trying a different HDMI cable has helped you resolve the temporary black screen issue on your system. We have not received any feedback from you so we will proceed to close this thread. Feel free to open a new topic in case you need further assistance.
Hugo O.
