Intel® ARC™ Graphics
3420 Discussions
Rainbow Six Siege - Frame drop issue (Vulkan-Direct X) Intel Arc -750
Yippee
I have some mad annoying fps drops that make the game unplayable and rainbow six siege is the only game where this happens and i don't know what to do, its happens Vulkan and direct x both Faceing these issue. first 30mins stable fps 250+ after 30mins getting fps drop 100fps. please resolve this issue thanks.
Processor -12th Gen i5-12600K
Ram - 16Gb 3200mhz
Graphics  - Intel Arc 750
os - Windows 11 pro 23H2 (64 Bit)
Intel Graphics driver version - 32.0.101.5768
RonaldM_Intel
Thank you for posting in our community.
I understand that Rainbow Six Siege's performance is showing sudden FPS drops after +30 minutes of what used to be perfectly fine gameplay. Let's look into it.
We have a new driver for you to update to 32.0.101.5971 so please try it out. This time do a clean driver installation using DDU just to be sure there isn't any corrupted .dlls or similar.
If the issue persists I would suspect a throttling issue. That is why I recommend running CapFrameX or similar tool that can capture performance indicators throughout the entire gameplay session. Refer to the instruction here for more info. Feel free to zip the resulting .JSON files and share them here so I can analyze them.
Finally, please let me know the following:
  • Make and model of your power supply.
  • GPU manufacturer (Intel, Sparkle, Acer, AsRock, etc.)
  • Have you overclocked the GPU?
Ronald M.
RonaldM_Intel
Hi again,
Did you get a chance to review my previous post?
The information requested is needed to properly tackle this issue.
Ronald M.
Yippee
Hey,
Power supply - Cooler master 550watts V2 230v
GPU manufacturer - Intel
am not overclocked my gpu
RonaldM_Intel
Hi @Yippee
Thanks for the information.
The CapFrameX data you shared is about 18 seconds of gameplay so it might not paint a clear picture. I noticed the VRAM usage is quite low (2.6 GB average) vs. the 4.7 GB average I saw in my latest test (CapFrameX data attached).
I do have to point out your power supply does not meet the minimum requirements for this GPU as it should be at least 600 Watts so please take this into consideration.
In my tests I could not see the issue, perhaps due to the fact the game has been updated and now supports DirectX 12.
Please update to driver 32.0.101.5989 and run the game on DirectX 12 (default API now) and let's see the results.
Ronald M.
