Intel® ARC™ Graphics
3472 Discussions
Refresh rate problems, Intel ARC B580
Drakkar
Bem, eu atualizei recentemente. Eu tinha um GTX1060 6 GB, o que me dava 144 Hz a 1920x1080 no meu monitor; no entanto, com minha recente compra do Arc B580, usando o cabo Ugreen HDMI 2.1, ele está me dando apenas 60 Hz a 1920x1080. Baixei o DDU para desinstalar drivers gráficos antigos, instalei os Intel e nada mudou; Eu ainda tenho meus 60 Hz.
Meu monitor é um GN246HL ACER, com entradas HDMI, VGA e DVI.
RandyT_Intel
Hi @Drakkar,
Informamos que só posso apoiá-lo em inglês. Usei uma ferramenta de tradução da web para traduzir essa resposta, portanto, pode haver alguma tradução imprecisa
  • Please provide the SSU log report and share it here so I can review your system's configuration.
  • Have you tried installing the latest BIOS on your computer?
  • Are you using a direct connection, or are you using video adapters, converters, or a docking station?
  • Have you tried using a different HDMI cable?
Warm regards,
Randy T.
Drakkar
1° OK
2°Yes, I have the latest version. I have an MSI PRO B650m-p.
3° Yes, I'm using it that way.
4° Yes.
RandyT_Intel
Hi @Drakkar,
Can we try this step, Install the latest Display's INF file for your display.
    • Some displays will require an update to their firmware. Consult with your display manufacturer for instructions on how to update it.
Randy T.
Drakkar
I think I've "discovered" the problem, as I said, my monitor has HDMI, DVI and VGA inputs. It seems that the monitor only delivers 144hz over DVI, which seems strange to me, but I think the problem is with my monitor.
Thanks for your attention.
RandyT_Intel
Hi @Drakkar,
Thank you for the update. I'm glad to hear you've identified the potential issue with your monitor's input settings. It does seem unusual that the monitor only delivers 144Hz over DVI, but it's good to know where the problem might be.
May I ask if you still need further assistance from my end?
Randy T.
RandyT_Intel
Hi @Drakkar,
I wanted to provide you with an update regarding your previous concern. We recommend using a direct cable connection for improved display quality and performance. For more information, please refer to our article titled "Using Video Cable Adapters, Splitters and/or Docking Stations in..." This article provides valuable insights into optimizing your setup.
I will be closing this inquiry. If you require further assistance, please submit a new question, as this thread will no longer be monitored.
Randy T.
TheMrHetch
Cara, eu to com um problema parecido, eu também tinha uma 1060, mas de 3GB, troquei pra intel arc b580 mas o refresh rate parece que tá em 50hz, tá muito lento, agora se eu conecto meu monitor secundario, que era um DVI, ele fica 75hz normal, isso ligando ele num adaptador de dvi para hdmi para display port kkkkkk, agora o hdmi normal pro meu monitor principal só fica em 60hz que parece 50
MUC
Honored Contributor I
The original query for this post was about the Acer GN246HL gaming monitor. It has a native refresh rate of 144 Hz, but can only achieve this via a dual-link DVI connection. This was also confirmed by product testing. When connected via HDMI, the maximum recognized resolution is 60 Hz. This is also confirmed by the EDID information uploaded by @Drakkar in the first post.
When connected via HDMI, this monitor will behave the same with all graphics cards, regardless of the manufacturer.
