Intel® ARC™ Graphics
3359 Discussions
Solved and temperature problem of the Intel Arc A770 graphics card
addelucas123
New Contributor II
Good afternoon
I wanted to comment once again, I tested with Red Dead Redemption 2 okay, with the high temperature issue, setting medium quality with Vulkan with the high temperature issue at night, that is, lighting goes up to 77 degrees, and during the day it goes down to 73 to 75 with Peak 76 degrees, I would like to improve that part with the lighting and high temperature equipment using drivers. Because yesterday I set everything to maximum and it got to 81 degrees. I don't know if it's still normal or not if it remains at 81. degrees, is it considered normal with the graphics maximum maximum maximum with Vulkan?
Labels (2)
Andres_Intel
Hello addelucas123,
Yes, it is correct, reaching 82 or 83 degrees in automatic it is normal since the card is operating within specifications Remember that changing fan and power settings can have an impact on the card's performance
Happy to hear that I have answered all your questions and thank you for all te comments and feedback provided, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
