Intel® ARC™ Graphics
3294 Discussions
Spark Arc B580
Vragec88
Débutant
2 488 Visites
Hello. I just want to report for the future drivers update that gpu doesn't recognize Variable refresh rate through HDMI or Displayport on my Acer 24G2W1G4 monitor, runs memory at full speed at desktop enviroment with PCIe aspm enabled. Also experiences some flickering in Crysis remastered.
System:
AMD R7 5800x3d
Aorus X570 Ultra MBO
Gskill Trident Z Neo DDR4 3600 cl16
Spark Arc B580 Titan
0 Compliments
11 Réponses
Cold_Burn
2 439 Visites
The Spark Arc B580 does not even recognise my display at all using DisplayPort.
I'm in talks with intel at the moment so will let you know when/if they find a fix.
Just to add that your monitor only support Variable refresh rate through DisplayPort.
Post a screenshot of your intel graphics software display page .
0 Compliments
Vragec88
Débutant
2 429 Visites
Yeah, I know. But I tried through hdmi anyway
0 Compliments
MUC
Contributeur émérite I
2 409 Visites
Variable refresh rates can only work with the AOC 24G2 monitor via DisplayPort. The monitor supports VESA AdaptiveSync there.
Via HDMI, Arc graphics cards can only support monitors with HDMI 2.1 VRR. This is not the case with the AOC 24G2.
0 Compliments
Vragec88
Débutant
2 404 Visites
Yeah. But as I said Variable refresh rate doesn't work via displayport either. In driver section display where is variable refresh rate indicated says it's not supported despite monitor being connected via displayport to B580. On my rx5700xt that I had before worked. 144hz refresh rate is correctly recognised but variable refresh rate doesn't work. That needs fixing
0 Compliments
Vragec88
Débutant
2 304 Visites
I'll give a little recap
VRR is not recognised via displayport even though monitor supports it.
Textures flicker in Crysis remastered
Call of duty modern warfare remastered runs great
Metro exodus enhanced runs great. Raytracing work like it should
Also, card is underutilized. That needs work for sure.
0 Compliments
Vragec88
Débutant
2 191 Visites
So to be exact and clear.
Variable refresh rate doesn't work through the display port even though monitor supports it, memory speed in desktop environment always runs at full speed. At least with latest 32.0.101.6253 driver.
Textures flicker in Crysis Remastered. Call of duty: Modern warfare 3 runs great, just like Metro Exodus enhanced with all settings turned to the extreme. And i do think that at 1080p gpu is underutilised.
0 Compliments
MUC
2 277 Visites
A monitor uses the cable to communicate its capabilities to the graphics driver of the source device.
AMD FreeSync and VESA AdaptiveSync use different messages. Please make sure that AdaptiveSync is explicitly activated on the monitor. You can read how to do this here from page 21.
0 Compliments
Vragec88
Débutant
2 273 Visites
It says freesync. Also it is enabled. No AMD freesync, just freesync. If it is not compatible ok. But from some forums I've red that A770 works with freesync monitors. Doesn't matter anyway. Card works ok. Just the niggle with vram speed in desktop and some textures in crysis are things that are visible to me.
0 Compliments
MUC
2 270 Visites
Please create a Report for Intel Graphics Drivers and attach the output file here.
0 Compliments
MUC
2 183 Visites
This does not seem to be an isolated case. If you create the desired report, we can compare it with the others.
0 Compliments
Vragec88
Débutant
2 177 Visites
Will do in the morning. I am at work right now. Thanks
0 Compliments
Répondre
