Intel® ARC™ Graphics
3455 Discussions
The arc control software can be installed, but it will not run.
enendie
Hello
I am one of the users of the Galaxy Book 2 Pro with Intel's arc graphics.
I downloaded a program called arc control through the Intel driver, but it is not running in the laptop.
How can I solve this problem?
Multiple reinstallations and boots do not run.
Attached is the screen of the Task Manager.
There are only a number of arc assists running, but the arc control does not open
Please tell me how to solve it
Thank you.
Window 11 eduction in use
AndrewG_Intel
Hello @enendie
We understand that you have some inquiries regarding the Intel® Arc Control Software on a system with Intel® Arc™ Graphics. We have a forum for those specific products and questions so we are moving it to the Intel® ARC™ Graphics Forum so this can get answered more quickly.
Andrew G.
David_G_Intel
Hello enendie
Thank you for posting on the Intel️® Arc communities. Please share with us the the Intel® System Support Utility (Intel® SSU) results to investigate:
David G
David_G_Intel
David G.
enendie
Thanks to feedback
i cant running Intel® SSU)
because I can't find the intel arc control file for intel ssu
how to find file ??
David_G_Intel
The SSU will help us get a better understanding of your current system setup, you don't need Arc control to run the SSU file. Please also share with us the following information:
  • Intel Arc model on the system
  • Do you get any errors or disclaimers when you try to use Arc control?
    • If you do, please provide a screenshot or video.
  • What driver version do you use?
Let us know if you have any questions.
David G
enendie
When I try to use arc control, it just darkens the screen, as in the recorded video, and nothing happens.
The arc control version is 1.0.4711
Both intel irises graphics and intel A350M graphics are 30.0.101.1329 versions
I will upload the video as a zip file, so please check it
David_G_Intel
Thank you for the information.
As a friendly reminder, please share with us the SSU results to continue the investigation. Also in the video we noticed that you're not using the latest drivers, so please follow the next steps:
After you complete those steps, try again and let us know if the issue persists.
David G
enendie
The graphics updater already says it's the latest version of graphics.
If you ignore this phrase and reinstall it, an error appears every time.
David_G_Intel
Thank you for the update, please confirm if this happens after you try the clean installation method. When you try this and get the error, what does it say specifically? Can you share a screenshot with us to investigate?
David G
David_G_Intel
@enendie let us know if you still need assistance.  We will be waiting for your response.
David G.
David_G_Intel
David G.
