Intel® Arc™ Discrete Graphics
3556 Discussions
Update ARC A Series Triggering Norton Block of Driver 32.0.101.8247
davidbmidi
Trying to install Intel GPU Driver DIRECT FROM INTEL Triggers Norton 360 as Threat
I have 2 ARC A series GPUs in 2 machines - an A380, and an A770. It happens on both pc's, both with Norton. Tried turning off smart protection, Norton still blocked the installs. I believe it has to do with the use of Powershell in the install program gfx_win_101.8247.exe package.
I've not had issues before when using the auto updater or the Intel Graphis Software App.
Please advise. Thanks in advance....
Dave
Notes below:
Description:
This download installs Intel® Graphics Driver 32.0.101.8247 for Intel® Arc™ B-Series Graphics, Intel® Arc™ A-Series Graphics, and Intel® Core™ Ultra Processors with Intel® Arc™ Graphics.
Version:
32.0.101.8247
Release date: October 23, 2025
Continues to trigger Norton as a virus threat
____________________________
Details
Threat name: IDP.HELU.PSE53%s_cmd
Threat type: Miscellaneous - This is malicious software that could harm your data, computer, or network.
Status: Repaired
Detected by: Behavioral Protection
On PC from: 9/9/25, 2:22 PM Update
Last Used: 10/24/25, 1:07 PM
Startup Item: Yes
Many users
Millions of users in the Norton Community have used this file.
Mature
This file was released 2 months ago.
High
The file risk is high.
Activity
Path | Type | Status
C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe | Process | Terminated
C:\Windows\System32\conhost.exe | Process | Terminated
C:\USERS\xxxx\APPDATA\LOCAL\TEMP\__PSSCRIPTPOLICYTEST_BVQ1FYON.Y4L.PS1 | File | Deleted
960E257C5A92724E9B70600293D65C52 | File | Deleted
ba0dd4fe923e/2025-10-24T18:07:24.837Z
davidbmidi
Should have included PC info. Both PC's are on Windows 11 Pro, 25H2. One (5700X AMD CPU and ARC A770 GPU) has 64GB Ram, the second 5600X AMD CPU and ARC A380 GPU) has 32GB Ram.  Have had both machines for a couple of years with no prior problems of this sort (anti-virus issues).
Dave
DLX2017
I have the same problem. System consist of a i5-4600k on a MSI PRO 2790-A WIFI with 32GB DDR5 5600 using an ARC A750 Limited  Edition. Windows 11 Home 25H2
RoadkillMerkin
I also have the same problem. My system:
MSI B760M gaming plus wifi.
Processor Intel(R) Core(TM) i5-14600KF (3.50 GHz).
Installed RAM 32.0 GB.
Installed GPU Intel(R) Arc(TM) B580 Graphics.
Windows 11 Pro (25H2).
TOS-IGC2356
Intel Arc A580 graphics driver failed to install.
RandyT_Intel
Hi @davidbmidi,
  • Please provide the SSU log report and share it here so I can review your system's configuration.
  • Can you confirm the NortonUI version currently installed on the system?
  • Have you tried using the Intel graphics driver version 32.0.101.8136?
  • Have you tried installing Intel graphics driver version 32.0.101.8136 after using Display Driver Uninstaller (DDU)?
Randy T.
TOS-IGC2356
All necessary files attached.
Not yet, I will try.
But,
The last time I did was to uninstall the old driver and install a new one.
That was it, no problem.
RandyT_Intel
Hi @TOS-IGC2356 ,
Just to clarify, am I currently speaking with the original poster of this thread, or is this a separate issue that aligns with the one initially reported? I want to ensure that the initial details are not being mixed with the latest updates. Also, could you please confirm if you're @davidbmidi? The username appears different, and I’d like to make sure I’m addressing the correct individual.
Randy T.
Neil_T
Hi, I had the exact same error and today I ran the update again to see if it now works.  This time it failed with a "download write error".  How can I resolve this please.
RandyT_Intel
Hi @davidbmidi,
@Neil_T @TOS-IGC2356 @RoadkillMerkin @DLX2017 To ensure we provide the most accurate support, please create a separate thread for each system or issue you're encountering. Since each setup may have different configurations, isolating discussions will help us tailor our responses more effectively based on the specific information presented.
Thank you for your understanding and cooperation!
Randy T.
Ozarks
I had the same issue using Norton 360. I temporarily disabled "Auto-Protect" and "Behavioral Protection" (screenshot attached) and was able to successfully upgrade from 8132 to 8247.  I did a "Clean" install for the upgrade. I then rebooted and verified the updated was installed and that the temporary protection disables were removed.
KevinBreazile
I am having the exact same error.  I would like to know how to resolve this issue.
LieDepuydt
Exactly the same problem with Avast Antivirus
Neil_T
Thanks for the info.  My problem has developed in that when I now try to run the Update I get a "Download Write Error" which I have raised a separate ticket for.  Interestingly the description of the download package in D&SA shows a size of 0 bytes!    I'll wait until Intel respond to my new ticket and (if necessary) try your disdable-Norton technique then.  Thanks again
VM25
Open the Intel exe file (for ex: gfx_win_101.8247.exe) using your archive manager (I use 7-zip). Extract its content to a folder and run Installer.exe from there. It worked for me.
Neil_T
That worked!!!! Many thanks.
RRuo58
Worked for me also. Thanks!
TOS-IGC2356
That worked for me, too. Thank you!
