CPU - ryzen 5700x
GPU - Intel arc A750
Ram- 16gb 3200mhz
I am having problem while playing valorant of fps keeps fluctuating widely sometimes it goes from 250 to 140/120 fps, drivers stability are not good for constant frames and frames remains below 200 while streaming on discord also. I am using this system for 2 year only.
Hello CAUSE,
- Was it working fine before?
- What was the last change in the system before you start having this issue?
- Are you using an Intel brand Arc A50?
- What are the troubleshooting steps that you tried so far?
Michael L.
Hello CAUSE,
Michael L.
Hello CAUSE,
I am sending another follow up on the information that I requested.
Michael L.
