Intel® ARC™ Graphics
3385 Discussions
Virtual Camera from Arc Control only 720p
RaysinToast
Hi
I just installed an Arc A310 on my system and running Arc Control (updated to latest)
In Studio, I have virtual camera on and set to 1080p and the source is a 1080p camera
However in OBS when I add the Intel Virtual Camera - it only lists 1280x720 30fps
is there a setting i'm missing? I've gone into the broadcast and capture settings and set them to 1080p as well but that didnt do anything
ReBAR is enabled.
RamyerM_Intel
Hello RaysinToast,
Thank you for posting in the communities. I would like to apologize for the delay in my response. Let me make it up to you. When you mention OBS, are you using a 3rd party software aside from the intel arc control? I just want to make sure we are on the same page. Additionally, may I please know if you are using a laptop or a customer build desktop system? You may send us the SSU logs so we can be more familiar with your specification. If you are using a customer build desktop, may I please know the camera model that model that you are using? I will be waiting for your reply.
Ramyer M.
Intel Customer Support technician
RaysinToast
Hi
no other software - just Intel Arc and OBS
this is a customer built desktop PC, the board is Asus Prime x670E-Pro with Ryzen 7950x.
The Camera is a Sony ZV-E10 (current video mode set to 1080p)
RamyerM_Intel
Hello RaysinToast,
Thank you for confirming. So far in the logs, I can confirm you are using the latest. Kindly please follow this article to use the Virtual Camera in Intel Arc Control: How Do I Use the Virtual Camera in Intel® Arc Control for Streaming or Content Creation? If you have followed this step already , please provide a screenshot of the view that you are using. Additionally, please share the version of your Intel Arc Control so we can take a further look at this for you.
Ramyer M.
RaysinToast
I have already tried those steps as they are the only way to get the device to show in OBS
here you can see the version, below
Here is the device without Intel Arc's virtual camera and going straight to OBS as a source - allowing to go 1920x1080
RamyerM_Intel
Hello RaysinToast,
Thank you for letting us know about the steps that you have already taken. I will proceed in coordinating this with our team so we can investigate this further. I will make sure to get back on this thread as soon as possible.
Ramyer M.
RamyerM_Intel
Hello RaysinToast,
Thank you for patiently waiting. We have here some steps that we would like for you to try, kindly please update your driver version to Intel® Graphics Driver 31.0.101.5445 (WHQL Certified). If the issue still exists, kindly please share with us the ArcControl logs found at C:\Users\<your_username_here>\AppData|Local\Intel\IGN\logs. I will be waiting for your reply.
Ramyer M.
RaysinToast
Updated to the driver you mentioned after DDU driver cleanup but still same issue, only showing as 1280x720 via Intel Virtual Camera
Logs attached as requested
RamyerM_Intel
Hello RaysinToast,
I am sorry to hear about this result. We will proceed in checking this logs internally and get back to you on this thread as soon as possible. Thank you for your patience and cooperation.
Ramyer M.
RamyerM_Intel
Hello RaysinToast,
Thank you for your patience as we continue our investigation. To assist us further, we would like to clarify a few details. May we please know the source from which you have obtained OBS Studio? The reason we ask is because it is available through various channels such as Steam, the Microsoft Store, and directly from the OBS website. Additionally, could you please inform us of the specific version of OBS Studio you are currently utilizing?
Ramyer M.
RaysinToast
I used the version directly from their site OBSproject.com version 30.1.2
RamyerM_Intel
Hello RaysinToast,
Thank you for confirming this details. We will continue on investigating this internally and I promise to update you on this thread once a solution is available.
Ramyer M.
RaysinToast
Hello
I have upgraded to driver 31.101.5534
Still same issue - still getting 1280x720 as only output no matter what resolution i select for the virtual camera
I have tested the camera on my Nvidia card and it's broadcast software outputs to 1920x1080 with same setup, the INTEL software still only outputting to 1280x720
has there been any development?
NormanS_Intel
Hello RaysinToast,
Thank you for your patience and for trying the latest graphics driver. After a thorough investigation and replication of the issue, we have determined that this behavior is expected, as the output resolution of our virtual camera is fixed at 720p.
I understand this may not meet your expectations, but it is the intended behavior for this feature. If you have any questions or concerns, please feel free to let us know.
Norman S.
NormanS_Intel
Hello RaysinToast,
I hope you had the opportunity to review the information I posted. If you have any questions or concerns, please feel free to let me know.
Norman S.
RaysinToast
Hi
I have had a chance to see the reply but i dont understand how this is your conclusion.
Is the application buggy? It clearly states the output of video and 1080p is selectable. I've seen others on forums have their outputs to 1080p as well.
NormanS_Intel
Hello RaysinToast,
Thank you for your response. I appreciate your concern, and I want to assure you that this update aligns with our investigation findings. I will relay your feedback to our team and ensure to provide an update in this thread. I'll keep you posted.
Norman S.
NormanS_Intel
Hello RaysinToast,
Thank you for your patience. After a thorough investigation, we have determined that the current maximum resolution is 720p. The option in Arc Control listing 1080p will be revisited in future updates, but we do not have an estimated timeline for this yet.
Thank you for bringing this to our attention. I will now close this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Norman S.
