Intel® ARC™ Graphics
Ankündigungen
3401 Diskussionen
Weird Graphic stretching in Call of Duty Modern Warfare 2(2022)
Carlos_C
Neuer Beitragender I
1.419Aufrufe
when I play Modern Warfare 2(2022) online, I sometimes get these weird stretches in my View that, while not really detrimental to the gameplay, can be a bit distracting.
What is detrimental to the gameplay, however, is that in some maps I can see straight through a texture/wall in a certain map, which is definitely not okay. I'm not sure if it's just my Graphics Card bugging out or if it's the game itself. I unfortunately could not upload a video with the texture glitch,  but it does occur often.
I can not confirm if this also happens in warzone as I do not play that game mode.
Attached is a video of the graphic stretching(you might have to squint to see it).
System:
CPU: Intel Core i9 9900KF
GPU: Intel Arc A770 LE 16gb
Motherboard Vendor & BIOS Version: Asus Rog STRIX Z390-F, BIOS Version: 2004. ReBAR enabled
Memory: 64gb DDR4 3600mhz RAM XMP Enabled
Operating System: Windows 11 Home 23H2
3 Antworten
Andres_Intel
Mitarbeiter
1.382Aufrufe
Hello Carlos_C,
Thank you for posting on the Intel communities. I see that you are having weird stretches in the View while playing Call of Duty Modern Warfare 2 (2022) with your Intel® Arc™ A770 Graphics (16GB), I will be more than happy to help you.
To understand the situation in a better way situation, please answer the following questions:
Andres P.
Andres_Intel
Mitarbeiter
1.326Aufrufe
Hello Carlos_C,
Were you able to run the Intel® SSU to know your system environment?
Andres P.
Andres_Intel
Mitarbeiter
1.293Aufrufe
Hello Carlos_C,
Andres P.
Antworten
