Intel® ARC™ Graphics
3360 Discussions
Witcher3 and ray tracing on Arc770
Roflosaur
When ray tracing is on, lighting glitches (video in attach). Also there is some vertical seams on screen center when the camera gives a close-up of faces, but I couldn’t capture it. In general, I noticed that this video card is characterized by flickering of objects when they are instantly loaded in some games, not only in The Witcher 3. For example, in Wolfenstein: New world order without ray tracing. This is much older game with same visible glitches.
System info:
OS Windows 10 22H2 build 19045.2965
CPU 12th Gen Intel(R) Core(TM) i5-12400F 2.50 GHz
RAM 32,0 Gb
GPU Intel Arc 770 16 Gb
Driver version 31.01.101.4824
Hugo_Intel
Hello Roflosaur
Thank you for posting on the Intel® ARC™ Graphics Communites.
I see from your post you are using driver 31.0.101.4824, Have you checked if this issue happens on driver 31.0.101.4826? I would suggest uninstalling driver 31.0.101.4824 using Display Driver Uninstaller and updating to the latest version so we can discard a corrupted driver problem.
In case the issue still happens, let us know the distribution service the game was downloaded from (Steam, Epic, GOG).
Hugo O.
Roflosaur
Well, last driver fix issue wit DX:HR performance (from list of fixes), but for Witcher 3 seems like ray tracing is still artefacting.
Jean_Intel
Hello Roflosaur,
We understand that after running the DDU and updating the driver to version 31.0.101.4826, the raytracing issue persists. There is a new driver update that includes multiple fixes, and we would like to recommend you install our new driver 31.0.101.4885, and check if the issue persists with the latest fixes.
Jean O.
Roflosaur
Install 31.0.101.4885, but not see the difference. There is need too look RTX behavior for comparing, I suppose. In the same game location. I just don't know what's normally for ray tracing for Witcher 3, because it's my first time experience with rays. But the advantage is still in favor of the classic render. In Cyberpunk 2077 rays looks fine, in Ratchet and Clank too, not counting the disappearance of glass near distant buildings at a certain angle.
Hugo_Intel
Hello Roflosaur
Could you please retest the game with our latest driver 31.0.101.4887? If the issue continues to happen please let us know whether this is the GOG, Epic, or Steam version of the game.
Also, Could you please confirm if you are using Display Driver Uninstaller before installing the drivers?
Hugo O.
Roflosaur
Excuse me, I'm install 4887, and yes, through UDD.
Hugo_Intel
Hello Roflosaur
Thank you for sharing all the details with us. I see the issue is still present after testing the latest driver 488, so we will further check this problem with our team. We will continue to post back once we have more information.
Hugo O.
Hugo_Intel
Hello Roflosaur
We want to let you know that this issue regarding the popping/disappearing shadows when using raytracing should have been resolved on the game's latest version. Please update to the latest available version of the game and check if the issue persists or gets fixed for you. You might also want to update to our latest driver version 31.0.101.4972 but just updating the game should fix the problem.
Hugo O.
Hugo_Intel
Hello Roflosaur
Have you had the chance to re-test the Witcher 3 on its latest version and with our latest driver? Based on our tests the issue should no longer be happening, let us know the results from your side.
Hugo O.
Hugo_Intel
Hello Roflosaur
I see no further comments on this thread so we will no longer monitor it. We hope the fix that was implemented on the latest version of the game helped with the popping shadows issues that you were experiencing. If you have further questions feel free to open a new topic.
Hugo O.
Inte Customer Support Technician.
